Missing 20 Amp Fuse - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 01-19-2013, 12:57 PM   #1 (permalink)
Points: 1,720, Level: 1 Points: 1,720, Level: 1 Points: 1,720, Level: 1
Member Number: 41881
Missing 20 Amp Fuse
Here's one for you gear heads. I was snooping around the Front Power Distribution Center, looking at the empty fuse spaces and matching the empty slot with the owners manual to see what's missing. Numbers 12 & 13 are normally empty. Number 16 is empty but owners manual shows it should have a 20 Amp fuse for the Powertrain Control Module! Should I have a fuse there but wonder why it's not there if it should be. This is on my 2005 300C
OhioDavidBS is online now
Old 01-19-2013, 03:00 PM   #2 (permalink)
Points: 51,993, Level: 1 Points: 51,993, Level: 1 Points: 51,993, Level: 1
Activity: 65% Activity: 65% Activity: 65%
Fisch's Avatar
Member Number: 22401
Just looked at mine. I'm only missing one in #13. I have a 15 amp fuse in #16. Mine is an '06 C.
Fisch is offline
The Following User Says Thank You to Fisch For This Useful Post:
OhioDavidBS (01-19-2013)
Old 01-19-2013, 04:26 PM   #3 (permalink)
Points: 34,423, Level: 1 Points: 34,423, Level: 1 Points: 34,423, Level: 1
Member Number: 1483
According to the 2005 300 Series & Magnum service manual Fuse #16 is a 20A and supplies the rear power outlet of the LX49 model, or station wagon.
To wit:
"POWER OUTLET
DESCRIPTION
Sedans are equipped with two 12–volt electrical outlets. Wagons are equipped with three 12–volt electrical outlets.
The outlets are located in the following locations:
Cargo area right quarter trim panel (wagons only).
Inside the center console.
Next to the ash receiver in the center stack.
The outlets in the console and quarter trim panel have power at all times, and include tethered covers. The outlet
in the ash receiver tray is shipped with power available only when the ignition is in the ON position. This outlet can
be changed to provide power at all times by moving a fuse in the fuse block."
So, what you are missing is only the Dodge Magnum. Good luck finding it!!
DESIREE is offline
The Following User Says Thank You to DESIREE For This Useful Post:
MADDOG (01-19-2013)
Old 01-19-2013, 05:22 PM   #4 (permalink)
Points: 28,799, Level: 1 Points: 28,799, Level: 1 Points: 28,799, Level: 1
MADDOG's Avatar
Member Number: 11602
^^^^ Good Stuff ^^^^
Michael
MADDOG is offline
Old 01-19-2013, 07:26 PM   #5 (permalink)
Nope, not the console power supply, owner manual says Powertrain Control Module.
Old 01-20-2013, 07:30 AM   #6 (permalink)
Member Number: 1483
Simple solution then: put a 20A fuse in the empty space, and the next time you go snooping around the PDC all will be in accordance with the owner's manual.
DESIREE is offline
OhioDavidBS (01-20-2013)
Old 01-20-2013, 08:44 AM   #7 (permalink)
It still makes me wonder why the Powertrain Control Module fuse would be missing and how could the car function without it.
Old 01-21-2013, 11:49 AM   #8 (permalink)
Points: 27,201, Level: 1 Points: 27,201, Level: 1 Points: 27,201, Level: 1
Activity: 23% Activity: 23% Activity: 23%
JonW's Avatar
Car: 2012 Bright White Chrysler 300C SRT8
Member Number: 288
DESIREE - The fuse you listed for the console power is the one from the REAR fuse box. His missing fuse is on the front fuse box.
OhioDavidBS - you do already have a 20 amp fuse in location #14 for the PCM.
The 2005 model year went through some changes between "early build" vehicles and later built vehicles. Specifically, the PCM for "early build" vehicles was an SCI bus communication variant while the later build versions made it to the CAN bus version. This mid-year PCM change could result in the discrepancy with having two fuses listed in the fuse box. Don't know that this is the case, but it would be my educated guess due to the mid-year changes.
SoCalLX - " Where Southern California Car Culture Meets Modern Mopar Muscle"
JonW is offline
The Following User Says Thank You to JonW For This Useful Post:
OhioDavidBS (01-22-2013)
Old 01-21-2013, 12:48 PM   #9 (permalink)
Member Number: 1483
[QUOTE=JonW;1134297]DESIREE - The fuse you listed for the console power is the one from the REAR fuse box. His missing fuse is on the front fuse box.
I stand corrected.
DESIREE is offline
Missing Fuse? JimC European & Diesel Powered 300 Models 15 03-27-2011 09:21 AM
Am I missing Something? bigsnake SRT8-Specific General Discussion 3 07-20-2007 11:16 AM
Fuse #13 in Front Fuse Box? kings11 Problems / Dealer Service 1 07-31-2006 12:10 PM
Fuse 17 Missing srt42 SRT8-Specific General Discussion 3 10-25-2005 09:22 PM
Front Fuse Box --- 60 Amp Fuse SilverSea Problems / Dealer Service 7 12-09-2004 02:58 PM
