I have a 2005 300c that since this weekend started up fine. So when I insert the key in the ignition and turn
to the on position all system seem good( radio on, dash light on) but gas gauge needle stays on empty( has 1/4 tank). Then
after five seconds everything powers off. When I insert the key back in to turn to the "On" position, nothing happens.
No lights, no radio, blank dash. Then when I hit the unlock button, and try it again then the lights and radio works again then shuts
off again. Then when attempting to start the car noting happens. I've checked all fuses, pulled some, battery fully charged and disconnected the negative terminal. I removed the ignition switch to see if I had a broken Ignition Actuator Pin. Check out fine, no broken pin. What else could be preventing the car from starting?
