Have to replace rear diff seals. - Chrysler 300C Forum: 300C & SRT8 Forums
 1Likes
  • 1 Post By Kaiser Bill
post #1 of 8 (permalink) Old 01-10-2017, 03:06 PM Thread Starter
Points: 21,112, Level: 1 Points: 21,112, Level: 1 Points: 21,112, Level: 1
Jim777's Avatar
I haven't confirmed it, other than drippings on the garage floor, but oil change tech said one of the seals is leaking. My two questions are, 1) do I need any special tools, and 2) do I have to drop or undo any of the suspension, or just unbolt the half shafts?
I imagine it's straight forward, but then last time I did those, it was on a '72 Datsun 240Z
Sent from my XT1254 using Tapatalk
Pic
'06 300C Hemi (the 5T FTR)
'05 GSXR1000
'06 GSXR750
Jim777 is offline
post #2 of 8 (permalink) Old 01-16-2017, 09:20 AM Thread Starter
Jim777's Avatar
Manual says have to lower diff from chassis, suspension to be compressed, etc.
Anyone done this themselves? Is it that much to-do to swap out the seals?
Jim777 is offline
post #3 of 8 (permalink) Old 01-16-2017, 12:14 PM
Administrator
Points: 101,395, Level: 1 Points: 101,395, Level: 1 Points: 101,395, Level: 1
Activity: 86% Activity: 86% Activity: 86%
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
axle seal or pinion seal?
Watching You Avoiding Me!
Kaiser Bill is offline
post #4 of 8 (permalink) Old 01-26-2017, 07:51 AM Thread Starter
Jim777's Avatar
Well, that is the question, isn't it. Honestly, I've yet to get under there myself, since that last post, if found out that there was more than one possibility.
The guy made me believe it's from the side of the pumpkin, other than that, what do I need to look for to determine?
Sent from my Pixel XL using Tapatalk
Jim777 is offline
post #5 of 8 (permalink) Old 01-26-2017, 08:26 AM
Administrator
3 seals...2 axles and the pinion (>driveshaft) seal.
best to check them all before trying to cure or you'll end up with bits everywhere but having failed to get all the parts you need before starting. You'll be walking back to the parts store to find what you want is 'on order, expected next week'
Jim777 likes this.
post #6 of 8 (permalink) Old 01-28-2017, 11:00 AM Thread Starter
Jim777's Avatar
"Propeller shaft"! Forgot that one. He did say "one side" so I'm figuring that clue. Either way you're right, if the same work had to be done for either of the other two, would do both at once.
If it's needed I don't have means to lift car while it's sitting on its own suspension.
Jim777 is offline
post #7 of 8 (permalink) Old 01-28-2017, 07:45 PM
Administrator
over here a propeller shaft lives in an old fashioned aeroplane! Occasionally we call it a propshaft, but not often. You're lucky, its an e xternal fix, you dont have to drop the pumpkin & delve inside
REMOVAL
1. Remove halfshaft(s).<A href="file:///C:/Users/MLA/Desktop/Service%20Manual/en_US/y2008/lx/si/xml/extxref_0354000370.xml"> (Refer to 3 - DIFFERENTIAL & DRIVELINE/HALF SHAFT - REMOVAL)
2. Using suitable screwdriver (1), remove axle shaft seal (2).
3. Visually inspect halfshaft seal journal for damage (excessive seal groove, nicks, scratches, etc.). Replace halfshaft if necessary.
INSTALLATION
1. Using Installer 9755 (2), install NEW axle shaft seal (1). Lubricate the inside diameter with Mopar® Gear and Axle Lubricant 75W-140 to protect seal during halfshaft installation.
2. Install halfshaft(s). <A href="file:///C:/Users/MLA/Desktop/Service%20Manual/en_US/y2008/lx/si/xml/extxref_0354000420.xml">(Refer to 3 - DIFFERENTIAL & DRIVELINE/HALF SHAFT - INSTALLATION)
3. Remove fill plug (1) to check and adjust rear axle fluid level. Top off axle with Mopar® Gear and Axle Lubricant 75W-140. Reinstall fill plug and torque to 50 N·m (37 ft. lbs.) torque.
as I'm a nice guy & those diagrams dont show, here they are below....removal followed by install......
ID:	146338   Click image for larger version
post #8 of 8 (permalink) Old 01-28-2017, 07:56 PM
Administrator
replace Gen1 SRT diff into a Gen2 SRT typan 2nd Gen SRT8- Mechanical 0 01-01-2017 07:25 PM
Smoothing out the ride added rear air bags yesterday doug515 2nd Generation Chrysler 300 Discussion 10 11-07-2016 09:52 PM
Changing the rear diff of a 2006 , 5,7 Theteese Power Train 6 04-19-2016 03:00 AM
Rear Diff, any DIY tips? Paul S. Safford 2nd Gen SRT8- Mechanical 12 11-20-2015 01:31 PM
Rear ABS Ring to Replace - Full Hub or Not? sibeer General Discussion on Issues / Trouble Shooting 2 10-07-2015 03:15 AM
