Loose Rattle In Front Suspension??? - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 83 (permalink) Old 01-17-2008, 03:58 PM Thread Starter
Points: 4,648, Level: 1 Points: 4,648, Level: 1 Points: 4,648, Level: 1
COPPERSHOT's Avatar
Car: 2005 CHRYSLER 300 LIMITED
Send a message via AIM to COPPERSHOT
I Searched The Past Posts And It Seems That This Is A Issue That A Few People Have...i Have The Loose Rattle Noise Coming From My Front Suspension...when I Go Over Bumps Even Small Ones The Car Shakes And Clunks In The Front End...i Have Just Replaced The Outer Tie Rods Worn Out From My 22"s, The Inner Tie Rods Were Just Done Today As Well As Brand New Kyb Struts...the Car Rides Awesome...tight Suspension..better Than Stock..but Still Clunks...the Technician Said The Sway Bar Links Are Tight And Everything Under The Car Is Solid!...we Cannot Find The Clunking....any Suggestions? Please Help!
"GET IT STRAIGHT BUSTER....IM NOT HERE TO SAY PLEASE....IM HERE TO TELL YOU WHAT TO DO....IF SELF PRESERVATION IS AN INSTINCT YOU POSSES YOU BETTER F#$%^N DO IT!...AND DO IT QUICK!... IM HERE TO HELP...IF MY HELP IS NOT APPRECIATED...LOTS OF LUCK GENTLEMAN." (WINSTON WOLF)
COPPERSHOT is offline
post #2 of 83 (permalink) Old 01-17-2008, 04:15 PM
Points: 1,069, Level: 1 Points: 1,069, Level: 1 Points: 1,069, Level: 1
BLKONBLKSRT8's Avatar
Car: 2007 CHRYSLER 300C SRT8
I have the same issue on my 2007. No problem with handling, so I am just living with it.
2007 SRT8 Black
No Mods Yet.
Would Like:
Exhaust - Louder
Intake - Colder
Grill - Grip.....
MyGig - Once I figure out how to install in a 2007
BLKONBLKSRT8 is offline
post #3 of 83 (permalink) Old 01-17-2008, 06:37 PM
Points: 11,441, Level: 1 Points: 11,441, Level: 1 Points: 11,441, Level: 1
NVmyC's Avatar
Well I don't know if this will help but my C has the ever so Evil black cloud over its head. Now I myself had this loose rattle and thought that it might be the plastic undercarriage protector, but after messing with that for over an hour and getting no results I decided to take it in and guess what? It needs 2 struts and 2 sway bar links. If it isn't your tie rods or the links then maybe the struts. I only have 10K miles on mine and it was bought new and I have yet to throw my rims on. Maybe this could help you. Best of luck finding the evil that lurks within the suspension.
NVmyC is offline
post #4 of 83 (permalink) Old 01-17-2008, 09:49 PM
Points: 7,891, Level: 1 Points: 7,891, Level: 1 Points: 7,891, Level: 1
Ball joints.
Northern300c is offline
post #5 of 83 (permalink) Old 01-18-2008, 05:42 PM Thread Starter
COPPERSHOT's Avatar
tech said the ball joints were tight...swaybar links were tight...and like i said brand new tie rods...inner and outer...and new struts...
northern...upper or lower? i have had bad ball joints on my cadillacs in the past and it does not sound like it at all...im at a loss...
post #6 of 83 (permalink) Old 01-18-2008, 07:32 PM
Elite Contributing Member
I once had some front end clunking and it was the upper control arm, which needed tightening.
I had previously had my upper control arm replaced because the seal boot was damaged during my KW install. The upper control arm was not tightened to spec and eventually started to clunk.
But this is a long shot solution for you, unless your upper control arm(s) were removed/replaced.
joey is offline
post #7 of 83 (permalink) Old 01-18-2008, 09:19 PM Thread Starter
COPPERSHOT's Avatar
never did mess with the control arms...but i will check it out....thanks for the info...it seems like the rattle is coming from the bottom...and i did notice that it is worse when i go over small bumps...it seems to "dribble" like a basketball...help?
post #8 of 83 (permalink) Old 01-19-2008, 02:56 AM
Points: 2,524, Level: 1 Points: 2,524, Level: 1 Points: 2,524, Level: 1
pmpinonu's Avatar
Send a message via Yahoo to pmpinonu
I seem to have the same problem and I took mine to a tech and they actually told me I need to have everything ball joints tie rods and on top of that he added that I would need to buy a whole new spindle which i found out is a 750 dollar part but I am currently having the tie rods and air suspensioin put in so we will see if that fixes anything before I go any further
23 years old, United States Army,
22" Focus Onyx
Apline W505 Head Unit W/ Blackbird
2 12" Alpine type E
E & G grille
Air Lift Air Suspension
Lambo Doors
8000K HID Lows
8000K HID Fogs
VIP Complete LED interior kit
Color Matched K2 Projectors W/ Halos
Window Tint
4 7" Apline Headrest Monitors
pmpinonu is offline
post #9 of 83 (permalink) Old 01-19-2008, 05:27 PM Thread Starter
COPPERSHOT's Avatar
The Only Other Thing I Have Left To Do Is The Ball Joints....the Tie Rods Only Fixed The Shaky Steering Wheel...
post #10 of 83 (permalink) Old 02-02-2008, 11:45 AM
Points: 539, Level: 1 Points: 539, Level: 1 Points: 539, Level: 1
The Upper strut bearing was gone out of our 2005 base 300. 25 000 km. I believe they replaced the whole strut. Took them a couple of months and two or three cars with the same problem to figure it out.
lwiltenb is offline
Weird loose rattle sound over bumps in the front end???? (Moved) SRT_3Hundy 1st Gen SRT8-Specific Wheels/Tires/Brakes/Suspension 314 12-26-2016 06:56 PM
=i Solved The Front Suspension Rattle!!!! (Moved) COPPERSHOT Suspension/Handling Modifications 31 10-01-2011 09:46 PM
Front Suspension Rattle after removing Eibach Springs Three00See Suspension/Handling Modifications 4 05-02-2010 11:13 PM
Loose Front - Hollow Thump/Rattle over Small Bumps WildTurkey 1st Gen SRT8-Specific Wheels/Tires/Brakes/Suspension 14 01-05-2008 04:26 PM
>> Loose Front suspension? SRT8 Tork Monster General Discussion 8 11-20-2006 10:04 AM
Replace with
