No tachometer or horn or signals or wipers or cruise cont. wiring / fuse help!!!!! - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 03-30-2011, 11:37 AM   #1 (permalink)
Points: 937, Level: 1 Points: 937, Level: 1 Points: 937, Level: 1
Car: 2007 Chrysler 300C
Member Number: 27620
Question No tachometer or horn or signals or wipers or cruise cont. wiring / fuse help!!!!!
i have a c&hrysler 300 2.7L. I have accidentally disconnected or blown smthng in the process. I have everything working except i have no use of anything attached to the steering column, such as turn signals, TACHOMETER, cruise control, HORN, wipers.... Any idea what wire or fuse i should check!?!. i have toyed around a lot with my car, so i imagine it was done while i had the guage cluster out, because once i plugged my guages back in, the TACHOMETER didn't work along with everything on the steering column. What wire or fduse would control everything running from the steering column (horn, signals, ect..) to ..... the abyss???.......... 8)
scfreedl is offline
Old 03-30-2011, 12:37 PM   #2 (permalink)
Elite Contributing Member
Points: 43,588, Level: 1 Points: 43,588, Level: 1 Points: 43,588, Level: 1
Bronek's Avatar
Member Number: 22917
Send a message via MSN to Bronek
Did you happen to plug the cluster in when the battery was connected still?
Sabrina - Srebrny Księżna
2005 300 Limited AWD ~ FE210 AWD? Maybe...
Click below for current mods + future plans
I do not believe in fire-breathing dragons, multi-coloured unicorns, good-willed people, omni-present creators, or other mythical creatures.
Bronek is offline
Old 03-30-2011, 01:56 PM   #3 (permalink)
Major Contributing Member
Points: 4,358, Level: 1 Points: 4,358, Level: 1 Points: 4,358, Level: 1
Car: 2010 chrysler 300c Bright Silver
Member Number: 9616
check the fuses in the rear power distribution box in the trunk next to the spare tire and a point to remember when working on anything electronic on these cars disconnect the battery as there is a lot of fussy computers etc and will save you a lot of grief.
jetech00001 is offline
Old 09-16-2011, 02:42 PM   #4 (permalink)
i did not disconnect the battery. but when i plugged the guage cluster back in it went haywire, everything started flashing and doing wierd stuff.....
scfreedl is offline
Cruise Control Fuse soulman97 General Discussion 2 02-27-2011 07:40 PM
What Fuse # Will Turn Off Windshield Wipers? DIGITALGRAVEL General Discussion 1 03-11-2009 07:12 PM
cruise fuse raspyvette General Discussion 5 09-10-2008 01:10 PM
