Caliper Loose but bolts are tight! - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 03-12-2012, 09:06 PM   #1 (permalink)
Points: 406, Level: 1 Points: 406, Level: 1 Points: 406, Level: 1
Car: 2006 Chrysler 300c
Member Number: 28788
Hi all,
I just did my oil change and was looking around for the cause of my front end rattle. I noticed my calipers are loose in their brackets. I mean really loose. I can grab them and shake them and get them clunk and bang around. I check the bolts and they are tight. I've done front brake jobs several times and I've never seen anything like this. Both calipers too!
The rattle is most noticeable at 20mph over cracked pavement or small quick impacts. The slightest brake pressure makes it stop. I just did the sway bar end links and the tension strut links are about a year old. Oh, 300c with 55k miles on the car.
Any suggestions/thoughts on this on? Thanks.
jgr325 is offline
Old 03-13-2012, 07:27 AM   #2 (permalink)
Points: 34,491, Level: 1 Points: 34,491, Level: 1 Points: 34,491, Level: 1
Member Number: 1483
Have you replaced the brake pads?
DESIREE is offline
Old 03-13-2012, 07:41 PM   #3 (permalink)
No, I haven't touched the pads. I look a look when I pulled the wheels to do the sway bar end links and they have lots of pad left. I'm going to take the brakes apart this weekend and see if any thing is broken and then grease the guide pins.
jgr325 is offline
Old 03-17-2012, 08:22 PM   #4 (permalink)
Well, the short version is the rattle is gone and it seems that the calipers are ok. I've never seen calipers with this much movement but it seems to be ok.
I pulled the wheels, popped off the calipers, greased the pins, and tightened the brake pad retainer clips. I also greased the outer tie rods (aftermarket Moog). Rattle is gone. I really didn't expect any of this to actually help so I'm happy.
jgr325 is offline
Sounds like a Bucket of Loose bolts! eortiz SRT8-Specific General Discussion 1 05-16-2010 01:05 PM
SD300 (Awe that sounds tight!) Icewood_Jr California Forum 25 02-20-2009 01:09 AM
How tight should the power steering be? JClishe General Discussion 3 01-16-2009 12:33 PM
How tight should the bolts be? BIGBODY300 Custom Wheels & Tires 3 03-27-2007 08:51 PM
My finances are little tight but I still want an SRT8 Sled SRT8-Specific General Discussion 8 06-28-2005 11:50 AM
