"need help asap" code p1521 knocking engine - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 04-04-2012, 06:29 PM   #1 (permalink)
Points: 7,874, Level: 1 Points: 7,874, Level: 1 Points: 7,874, Level: 1
MR. GAMBINO's Avatar
Car: 2007 CHRYSLER 300C HEMI 5.7L
Member Number: 17961
Send a message via AIM to MR. GAMBINO Send a message via MSN to MR. GAMBINO Send a message via Skype™ to MR. GAMBINO
Exclamation "need help asap" code p1521 knocking engine
Has anyone have this problem this morning I started my car and wont start that easy plus its making noices when I check for engine light codes it gave me the P1521 "wrong engine oil type" but what about the knocking noices? took the car to the dealer but just to check compresion they want $600.00 + $100.00 diagnosis so any help that you can give me my car is a 2007 Chrysler 300c HEMI 5.7L stock.
2007 300c HEMI 5.7L
K2 HELO
KNN AIR INTAKE
AIRAID SPACER
RESONATOR DELETE
5% TINT
LED SIDE MARKERS
LED TAILLIGHTS
LED FRONT TURN SIGNALS
HID 8000k ON FOG LIGHTS
MR. GAMBINO is offline
Old 04-04-2012, 06:51 PM   #2 (permalink)
Points: 20,144, Level: 1 Points: 20,144, Level: 1 Points: 20,144, Level: 1
Sodak's Avatar
Car: 2006 Chrysler 300c SRT8
Member Number: 24540
All i can find on this is wrong oil or not enough oil or might be the oil pressure switch p0520, did you just do an oil change ?not sure about the knocking,also found this helpfull tool by fisch.
Equus - OBD2 Definitions - Diagnostics Made Easy
See My Garage
http://www.300cforums.com/forums/garage/1129
SRT A Factory Hotrod
Sodak is offline
Old 04-04-2012, 07:03 PM   #3 (permalink)
I had the oil changed in Chicago IL. About 4k miles ago and dealer checked the oil level and viscosity and its ok but I just hope is not a blown engine Thanks for your reply
Old 04-04-2012, 07:06 PM   #4 (permalink)
BIG OLE DOG
Points: 186,550, Level: 1 Points: 186,550, Level: 1 Points: 186,550, Level: 1
Activity: 76% Activity: 76% Activity: 76%
Northern Rider's Avatar
Member Number: 538
Possibly a tank of bad fuel?
- Patrick -............ Latest List of Road Racing Mods ..........
"Life is not measured by the number of breaths we take,
but by the moments that take our breath away” .
Northern Rider is offline
Old 04-04-2012, 07:13 PM   #5 (permalink)
The dealer techician just check one of the cylinders and it has a lot of fuel in it
Old 04-04-2012, 08:35 PM   #6 (permalink)
Sodak's Avatar
Bad injector?
Sodak is offline
Old 04-04-2012, 08:39 PM   #7 (permalink)
Points: 28,752, Level: 1 Points: 28,752, Level: 1 Points: 28,752, Level: 1
MADDOG's Avatar
Member Number: 11602
Bad injector, bad plug or bad coil it sounds like to me.
Michael
MADDOG is offline
Old 04-04-2012, 10:33 PM   #8 (permalink)
Thanks guys
Old 04-03-2013, 08:14 AM   #9 (permalink)
Points: 598, Level: 1 Points: 598, Level: 1 Points: 598, Level: 1
Car: 2012 Chrysler 300C
Member Number: 42503
p1521 is for VVT issues. You changed oil, My car owners manual is VERY specific to use ONLY 5W20 Oil meeting Chrysler spec. If you didn't do this and know for sure it was done properly you are not following the manual and the manual identifies the VVT may not function properly .
vettdvr is offline
Old 04-03-2013, 07:00 PM   #10 (permalink)
Points: 34,413, Level: 1 Points: 34,413, Level: 1 Points: 34,413, Level: 1
Member Number: 1483
I don't believe the 2007 Hemi has VVT, but the 2007 MDS does require the 5W20 oil for proper functionality. So if they put in a higher viscosity oil the on-boarded nanny will complain about it!
How old is the battery Mr Gambino? Weak batteries have been known to cause all kind of false alarms.
DESIREE is online now
Engine code P1521 machine463 General Discussion on Issues / Trouble Shooting 4 06-24-2011 07:38 AM
LIMITED TIME ONLY: Hawk is cheap! Don't "brake" the bank; huge savings on Hawk at PFYC.com w/promo code Redshift Vendor Deal Zone 1 10-21-2010 11:30 AM
Code P1521?? AP24LA Problems / Dealer Service 12 01-28-2009 03:33 PM
Diagnostic Trouble Code "P 0645" dunsantos Problems / Dealer Service 3 07-18-2007 10:08 AM
OBD-II Error code "PO430" Cruznit Performance General Discussion 2 03-21-2007 02:20 AM
