Replacing battery. What's really involved? - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 12-02-2012, 09:02 AM   #11 (permalink)
Administrator
Points: 286,579, Level: 1 Points: 286,579, Level: 1 Points: 286,579, Level: 1
Activity: 30% Activity: 30% Activity: 30%
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Well mine lasted 7 years and I changed it this spring. Always had it on a battery tender during the winter, but it finally gave up the ghost. Nothing unusual for me either, but the vent hose is a must. You will need to do the window, power seat and steering recallibrations which is no big deal.
Bernie
Click Here To Put Your Location On The 300cforums.com Member Map
Rambit is offline
The Following User Says Thank You to Rambit For This Useful Post:
Stockholm 300C (12-02-2012)
Old 12-02-2012, 09:08 AM   #12 (permalink)
Administrator
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
BTW, I also had to change my Jeep's battery this summer after 4 years. I couldn't live with the white case Mopar has as a direct OEM replacement at least in Canada. It was OK for my car as it's hidden in the trunk, but a white battery in a black Jeep was awful. Went to Canadian Tire and their OEM replacement was white also. Turns out both are made by Exide. I went with the Terminator in a black case, the optional battery with more cranking amps etc and a 4 year warranty.
Bernie
Rambit is offline
Old 01-07-2013, 10:52 PM   #13 (permalink)
Points: 850, Level: 1 Points: 850, Level: 1 Points: 850, Level: 1
NOTBASIC's Avatar
Car: 2005 Chrysler 300c
Member Number: 32736
I just got the Autozone dura last platinum.... It's a AGM battery.... My question is that there's like a exhaust tube that was installed on the oem one and this one doesn't have a place to install one. I went back to them and they stated that I purchased a premium battery that doesn't let off the fumes of a standard battery so I have nothing to worry about...... I called three of their locations and they all said the same. I just wanted to check with u guys to make sure..... Thanks for the advise and I pray they are right
NOTBASIC is offline
Old 01-08-2013, 11:52 AM   #14 (permalink)
Points: 37,799, Level: 1 Points: 37,799, Level: 1 Points: 37,799, Level: 1
blacknight's Avatar
Member Number: 28779
I'm wondering the exact same thing.
I have an 2006 AWD C with the original battery.
I'm looking into replacing it soon. But when I looked in the trunk, I didnt see anytype or hose or anything. on the right all I saw was the battery held in place by the battery tie down strap
I did hear that the battery I have is sealed or something so I assume it's recommended I replace it with the same battery (sealed)
In my previous vehicles I'm always used the Sears DieHard batteries with absolutely no problems.
With the exception of my last vehicly (04 Grand Cherokee) I used the Autozone Duralast and that was fine.
Does you car have Ka-chunka-chunk
HEMI + AWD = OMG
blacknight is offline
Old 01-08-2013, 11:59 AM   #15 (permalink)
NOTBASIC's Avatar
Someone answered on another post I made and they said that if its a AGM battery it doesn't let out gases like the standard batteries do. So I think u are all good also bro
NOTBASIC is offline
Old 01-08-2013, 12:47 PM   #16 (permalink)
blacknight's Avatar
ok, stupid question....
What is an AGM battery?
Old 01-08-2013, 12:56 PM   #17 (permalink)
blacknight's Avatar
THis is the battery I was considering.
Stock is 730cca.
This one is 790cca
Old 01-09-2013, 09:12 PM   #18 (permalink)
Points: 20,896, Level: 1 Points: 20,896, Level: 1 Points: 20,896, Level: 1
Stockholm 300C's Avatar
Car: 2007 Chrysler 300C
Member Number: 13392
Not stupid. I had to look it up.
From ASK.com
Absorbed glass mat
AGM batteries differ from flooded lead acid batteries in that the electrolyte is held in the glass mats, as opposed to freely flooding the plates. Very thin glass fibers are woven into a mat to increase surface area enough to hold sufficient electrolyte on the cells for their lifetime. The fibers that compose the fine glass mat do not absorb nor are affected by the acidic electrolyte. These mats are wrung out 2–5% after being soaked in acids, prior to manufacture completion and sealing.
The plates in an AGM battery may be any shape. Some are flat, others are bent or rolled. AGM batteries, both deep cycle and starting, are built in a rectangular case to BCI battery code specifications.
Stockholm 300C is offline
Old 01-10-2013, 09:13 AM   #19 (permalink)
blacknight's Avatar
Hmmmm.
That's interesting
Now if I just go to autozone, Pep Boys or something and give them the details of my car, they should be able to match up the correct battery and know that it's in the trunk right?
Maybe I have to look more in depth while in the trunk, but I dont remember seeing some type of hose or something for ventilation.
Just the tie down strap going around the battery and holding it in place.
Looks like something from the factory and not something someone rigged up...
Where would this hose be and look like?
Old 01-10-2013, 11:09 AM   #20 (permalink)
NOTBASIC's Avatar
It's a black host that was plugged into the positive side of the battery with a 90 degree nipple on it..... And as for ur comment regarding autozone knowing what I need yea I feel the same way.... I run a specialty store and I hear a lot of nonsense these people that work at the big box masses tell customers that is so off target!!!!! Replacing battery. What's really involved?-imageuploadedbyautoguide1357837756.385662.jpg
NOTBASIC is offline
Procedure for charging or replacing battery Dan SS2471 SRT8-Specific Problems/Dealer Service 10 05-05-2013 05:57 PM
Car Shuts Off After Replacing Battery WeStayClean General Discussion on Issues / Trouble Shooting 3 12-03-2012 08:33 AM
Replacing the Key Battery? BigIan European & Diesel Powered 300 Models 6 03-30-2012 07:39 PM
What's involved in 426 install? racy Performance General Discussion 15 05-15-2008 09:54 AM
replacing car battery Ramiro0727 Car Audio/Alarms/UConnect/Navigation 7 07-23-2007 12:13 AM
