real bad gas milage - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 12-09-2012, 02:41 PM   #1 (permalink)
Points: 960, Level: 1 Points: 960, Level: 1 Points: 960, Level: 1
Car: 05 chrysler 300c
Member Number: 40154
real bad gas milage
ok well here the deal...
im only getting avg 10 mpg on the 300c 5.7 auto
im running 180* thermo
cherry bomb cat back
mopar cold air intake
dioblo 93 octane tune
i know this isnt normal...
i recently changed the plugs and wires. car runs greats!
what can i do here??
also car is on some heavy 22" and its a 2005 300c
james300c is offline
Old 12-09-2012, 03:12 PM   #2 (permalink)
BIG OLE DOG
Points: 190,086, Level: 1 Points: 190,086, Level: 1 Points: 190,086, Level: 1
Activity: 57% Activity: 57% Activity: 57%
Northern Rider's Avatar
Member Number: 538
What kind of driving do you do?
What I mean is how much highway at cruising in a week? How much stop and go city driving? Does the car idle for long periods?
Also - are you in a colder climate zone this time of year?
- Patrick -............ Latest List of Road Racing Mods ..........
"Life is not measured by the number of breaths we take,
but by the moments that take our breath away” .
Northern Rider is offline
Old 12-09-2012, 05:22 PM   #3 (permalink)
its a mix of both really city and highway.. i work less then 10 mins away from work and that city diving rest is all highway really.. most the time i hit green lights all the way to work im in center in st louis mo maybe in the 40* its 48* today
i looked on the preditor for a eco tune for winter but there isnt one..
Old 12-09-2012, 06:05 PM   #4 (permalink)
BIG OLE DOG
Member Number: 538
The 5.7 should get much better mileage, given the conditions. I had two 5.7's and if the engine is revving under 2500 rpm, I would get from 18 - 23 mpg.
I would start with your Predator, by taking the tune out and going back to stock. It doesn't matter if you still have 93 octane in the tank. The ECM will handle that.
I would also make sure the air filter is clean.
I'd run it for a week like that and see what happens . . .
Old 12-09-2012, 07:30 PM   #5 (permalink)
Points: 4,701, Level: 1 Points: 4,701, Level: 1 Points: 4,701, Level: 1
fanofsteel's Avatar
Car: 2012 Gloss Black 300 SRT8
Member Number: 3797
Hey James,
I had the same thing happen with my 05 300C recently. It turned out to be a bad Oil Pressure Sensor. I found out a couple different ways:
1. Used the power on/off technique to get the diagnostic code (would come on sometimes, but not all the time)
2. Hold the two inner buttons on the wheel to get to the advanced screen between the gauges and look at the oil pressure. It will be out of wack. Mine read 99 when it should be around 45-55 psi.
Now... replacing the sensor on your own is bit of a bitch because it is located directly behind the Alternater so you have to take the alternater off and there isn't a whole lot of space to get a wrench in there. If you are doing this yourself, the replacement sensor (if that is the problem) is made of brass and will easily snap off if you over tighten it... sound like I had experience with that... yeah and I was so pissed!!!!
Why do I mention the Oil Pressure Sensor, because if it doesn't work properly MDS never kicks in.
Hope this helps.
FanofSteel
All Possible Options - Black Chrome too
20" Charger SRT Chrome Wheels
20" Pirelli Scorpion Ice & Snow all around
fanofsteel is offline
Old 12-09-2012, 07:33 PM   #6 (permalink)
Points: 2,382, Level: 1 Points: 2,382, Level: 1 Points: 2,382, Level: 1
MikeHTally's Avatar
Member Number: 6769
That ten minutes from work is what's killing your mileage. The engine never warms up (and letting it idle to warm up isn't going to help). You might try cleaning/replacing the PCV valve. Same for the EGR valve. How are you determining the mileage?
MikeHTally is offline
Old 12-09-2012, 08:16 PM   #7 (permalink)
i remote start the car in the am runs about 5 mins or so and warms up
the mileage is determined by filling up the tank driving 100 miles and then running them numbers... also by the dash as well...
also the oil pressure is fine.. i know about the easter egg on the steering wheel and oil pressure reads just fine..
im just wondering if it isnt the plugs i installed there are ngk copper..
Old 12-09-2012, 08:19 PM   #8 (permalink)
Major Contributing Member
Points: 11,765, Level: 1 Points: 11,765, Level: 1 Points: 11,765, Level: 1
onesickhotrod's Avatar
Member Number: 22985
Send a message via AIM to onesickhotrod
Sounds like a all around tune up is in order... pcv/plugs/wires/check air filter. The oil pressure should be checked as well. Do you feel the mds at all?
ONESICKHOTROD
2005 modified 300C
Rochester, New York
Visit my garage for details
onesickhotrod is offline
Old 12-09-2012, 08:32 PM   #9 (permalink)
plugs wires and pcv were changed 5k ago.. and the mopar cold air was install about 7k fliter is clean
ive been all though it all... and cand find the problem...
i think im gonna pull the plugs and see how there firing..
mds idk?
Old 12-09-2012, 08:37 PM   #10 (permalink)
BIG OLE DOG
Member Number: 538
Another thought about the 93 octane tune - my experience with Diablo canned tunes has been very positive - both the 91 and the 93 tune generaly improve engine efficiency and - with an easy foot on the throttle - better mileage.
Perhaps the culprit could be the fuel itself. If it is not to the claimed spec, your mileage could suffer. There has been a few reports here about 'bad' fuel . . .
Bad Gas milage? IID General Discussion on Issues / Trouble Shooting 14 02-28-2012 04:31 AM
milage ejh714 European & Diesel Powered 300 Models 20 10-14-2009 08:34 PM
Gas milage with SRT 8 agepag Canada / Mexico Forum 17 03-23-2008 01:32 PM
milage Fabes General Discussion 7 03-03-2007 09:16 AM
Milage haas SRT8-Specific General Discussion 10 08-01-2006 11:40 PM
