Old 09-09-2005, 03:46 PM   #1 (permalink)
phunter1
Member Number: 2790
481 Hp 5.7 Hemi
In the last few issues of Hot Rod, they have been working with the 5.7 hemi crate motor, which is identical to our engines except for the fuel system, which is either a carb or throttle body EFI. Thsi is becasue of the need to put the thing in older cars. Anyway, in the October issue, they changed the cam to a Competition Cams XFI273. While much stronger than the stock cam, it is far from a race cam. Anyway, Hot Rod could not find a way to over come the 5700 rpm limit of the Mopar PCM, so the used a Ford PCM on the hemi. The net result was 481 hp @ 6500 rpm and 415 ft/lb @ 5000 rpm. This was on a dyno running open headers.
Interestingly, the were able to get 401 hp out of a bone stock 5.7 hemi, by changing to the Ford PCM and reving the engine to 6000 rpm., again on a dyno with headers.
They tried the 6.1 SRT8 manifold on the engine, but actually produced less power due to the port size mismatch. Future tests will use this manifold with some port matching work to see if it will produce more power. Overall, it looks like there is a lot more power to be had from the 5.7 Hemi, once the after market figures out how to deal with the PCM
Phil
2006 300C
Brilliant Black
phunter1 is online now
Old 09-09-2005, 03:55 PM   #2 (permalink)
vvv90
vvv90's Avatar
Member Number: 1919
Something seems fishy here.....
I'm not saying BS but something seems left out.
JUST a cam swap with stock heads, intake, and open headers makes 481HP?
Well then the cats and mufflers run on the JohnHennesey SRT-8 with their top end package must be robbing LOTS of power because they're output in HP is about the same.....That's WITH cam, head work, SRT-8 Manifold, etc...
vvv90 is offline
Old 09-09-2005, 04:14 PM   #3 (permalink)
Meister
Meister's Avatar
Member Number: 942
Originally Posted by vvv90
...JUST a cam swap with stock heads, intake, and open headers makes 481HP?...
Don't forget the Ford PCM, vvv90--that appears to have removed a primary obstacke to higher power output.
But still....
PPP Meister Warrior cam-#01
GSM 1000 hp halfshafts-#01
SRT8 instrumentation-#01
Goodyear F1 GS-D3s-#01
Shock tower braces-#01
MotoRad 176° tstat-#01
DR Stage 2 heads-#02
SRT8 Brembos-#01
GSM 5.7L Mod-#01
Fast56K-TCM-#01
AirHammer-#01
12.97@107.7-#01
176 mph-#01
Willow: 1:44-#01
Laguna: 1:45-#01
12.3/113.8/1.74
Meister is offline
Old 09-09-2005, 05:16 PM   #4 (permalink)
JP300c
JP300c's Avatar
Car: 2006 6.1L V8 300C SRT8
Member Number: 2650
Send a message via AIM to JP300c
maybe this is an ignorant question (i havent seen the answer yet) if that 481hp is unlocked...how much will the C's tranny and rear end hold?
AFE | Corsa | DiabloSport
Billet Technology Sponsor Car Central IL
JP300c is offline
Old 09-09-2005, 05:19 PM   #5 (permalink)
5point7
5point7's Avatar
Car: 05 yes! 300C
Member Number: 533
The only thing fishy vvv is that your most likely comparing FLYWHEEL HP ratings from the magazine article (motor is on a stand with open headers, to Rear Wheel HP numbers that Hennesey puts out.
Doesn't sound fishy to me at all. I've read in quite a few publications that the new 5.7 is the "small block chevy" motor of the new century.
I think you will see some insane power numbers from it once the code is unlocked.
SOLD 2005 Silver C...Life goes on.
5point7 is offline
Old 09-09-2005, 05:29 PM   #6 (permalink)
phunter1
Member Number: 2790
Hi,
This is an engine running on a dyno, through open headers. There is no exhaust system, drive train, etc. Clearly, we are talking flywheel horespower.
Old 09-09-2005, 05:38 PM   #7 (permalink)
Model 57
Car: 2006 Bright Silver, Dk/Lt Slate interior 300C
Member Number: 1615
Sounds like some fun times ahead for us to me. Unlocking some serious horsepower sounds like what we have been looking for.
Model 57 is offline
Old 09-09-2005, 05:55 PM   #8 (permalink)
Northern Rider
Northern Rider's Avatar
Member Number: 538
Great times ahead, indeed. The 5.7 is quite "detuned" in its present form.
Lots of potential left in this strong, rugged design, IMO.
Northern Rider is online now
Old 09-09-2005, 06:46 PM   #9 (permalink)
phunter1
Member Number: 2790
As I said earlier, the stock motor made 401 HP, with no other changes than the Ford PCM, which allowed the motor to rev to 6000 rpm. For baseline purposes, the stock out of the box motor produced 376 HP at 5700 rpm. Again, this is on a Dyno, through open headers, so 340 HP installed in the car with an exhaust system is probably pretty accurate.
At any rate, it looks like there is a lot of potential in the 5.7, once the tuners figure out how to get past the 5700 rpm limit.
Phil
Old 09-09-2005, 09:53 PM   #10 (permalink)
mvpatriot
mvpatriot's Avatar
Member Number: 2168
::drooling::
2006 300C Brilliant Black
-Black Devino Duel 22x9.5 +18 offset
-Universal Air Suspension/Dakota Digital Gauge
-BCool Mesh Grille
-V.I.P. Headlight Covers
-Nu Image Diamond Gauges/Clock (yep thats me in the RIDES ad)
-Satin Nickel NYC Dash Kit
-Autovation Aluminum 4pc. Pedal Kit
-Smoked Tail Lights and Side Markers
-Viper Pager
-20% Tint
mvpatriot is offline
