Enigine and Red Lightning Bolt Symbols - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 17 (permalink) Old 03-03-2014, 05:08 PM Thread Starter
Points: 18,456, Level: 1 Points: 18,456, Level: 1 Points: 18,456, Level: 1
acesrt's Avatar
Car: 2006 Chrysler SRT-8
The Enigine and Red Lightning Bolt Symbols are lit on the dash
06 SRT just over 100k.
Why might these come on?
acesrt is offline
post #2 of 17 (permalink) Old 03-03-2014, 05:29 PM
Points: 30,781, Level: 1 Points: 30,781, Level: 1 Points: 30,781, Level: 1
CNISTER's Avatar
Does it start? Drive it to Autozone or do the "Key Dance" and tell us the codes. the Red Lightning bolt I believe has something to do with the fly by wire throttle.
CNISTER is offline
post #3 of 17 (permalink) Old 03-03-2014, 05:31 PM Thread Starter
acesrt's Avatar
Yes it starts but sounded kinda rough...... it was 14 degrees f in nj today though
acesrt is offline
post #4 of 17 (permalink) Old 03-03-2014, 06:20 PM
Points: 84,023, Level: 1 Points: 84,023, Level: 1 Points: 84,023, Level: 1
MADDOG's Avatar
Sounds like a throttle body problem but to determine exactly what the problem is, we'll need the Diagnostic Trouble Codes (DTC's) from your car's computer. Here's the instructions on how to read the codes via your EVIC:
Checking For Codes - Doing The "Key Dance"
Michael
MADDOG is online now
post #5 of 17 (permalink) Old 03-04-2014, 08:30 AM Thread Starter
acesrt's Avatar
p2181
p2181
acesrt is offline
post #6 of 17 (permalink) Old 03-04-2014, 09:18 AM
CNISTER's Avatar
Possible causes
- Low coolant level
- Faulty Engine Coolant Temperature Sensor
- Stuck or leaking thermostat
- Engine Coolant Temperature Sensor harness is open or shorted
- Engine Coolant Temperature Sensor circuit poor electrical connection
Found this online, Obviously first check the coolant level.
Next I would check your temp when fully warmed up. If you hold down the Compass and Music buttons together for a few seconds it will load up a secret menu screen. There is a screen that will give a digital reading of Water temp. Give us that temp when operating the car normally,
Too Hot, the thermostat may be stuck shut/faulty
Too Cold, the thermostat may be stuck open/faulty
Either of which would require a replacement. BUT the sensor may also be faulty, I would think this would give an OBVIOUS wrong reading, like 100 degrees when driving around.
As far as the last two options, I would not be able to really help there. Normal operating temp on a stock 5.7 is around 200-210 F, I would think the 6.1 is around that as well.
Unless of course you have a Programmer such as a Diablosport and have moved the fan settings without changing the thermostat?
Are there any mods you have on your car?
CNISTER is offline
The Following User Says Thank You to CNISTER For This Useful Post:
MADDOG (03-04-2014)
post #7 of 17 (permalink) Old 03-04-2014, 06:19 PM Thread Starter
acesrt's Avatar
The car is 100% stock.
The other day I turned on the heat after the engine was warmed
and got cold air blown for at least 1 min......
mean anything?
acesrt is offline
post #8 of 17 (permalink) Old 03-04-2014, 08:10 PM
CNISTER's Avatar
Not usually, I am not 100% sure, but I think the heater core would be blocked off from coolant unless the heat is on. I think its a fairly new thing on cars. So it would still have cooler coolant in the heater core untill it was circulated.
CNISTER is offline
post #9 of 17 (permalink) Old 03-05-2014, 06:07 AM
Elite Contributing Member
Points: 43,612, Level: 1 Points: 43,612, Level: 1 Points: 43,612, Level: 1
onesickhotrod's Avatar
Send a message via AIM to onesickhotrod
The thermostat is a cheap and easy fix. If you have never done that I recommend it asap. Also time for a coolant flush.
Rochester, NY
See my garage for upgrades
onesickhotrod is offline
post #10 of 17 (permalink) Old 03-17-2014, 08:54 AM Thread Starter
acesrt's Avatar
Yesterday the air blew cold for ten min after the engine warmed up. Shut the fan, waited a min, turned it back on and it blew hot air for one min, then back to cold. Also the temp readout on the dash stayed in the cold area for the entire 1 hr drive.
code p2181 is still present
acesrt is offline
Red Lightning music realsmooth Problems / Dealer Service 15 02-10-2016 11:28 AM
Red Lightening bolt and no codes blueeyed300 General Discussion on Issues / Trouble Shooting 12 07-30-2012 07:02 AM
Red Lightning Bolt (Moved) mako Problems / Dealer Service 25 12-09-2011 12:09 PM
Lightning Bolt at 80mph - and Stalling - Help! TopTrainer 1st Gen SRT8-Specific Problems/Dealer Service 14 03-06-2011 09:12 AM
Red Lightning spacenase UK & Europe Regional Forum 20 10-11-2010 06:21 AM
Replace with
