Old 07-05-2006, 11:55 AM   #1 (permalink)
Member Number: 5420
Autostick Problem
Does any body have an autostick problem with the 300c. When I accererate hard my autostick will not shift under my command. It ingors my shift commands and shifts automatically. This is very furtrating to me!!! The dealership insists that this is the way the autostick works. Is this true? They say that there aren't any flash updtaes to correct this issue. My son has a Charger RT and his auotsick shifts under user command all the time regardless of accerleation. Please help to resolve this issue.
Thanks,
Gates
gates is offline
Old 07-05-2006, 12:05 PM   #2 (permalink)
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (18)
Thanks,
Gates
is the R/T a 6.1L? I posted a similar question a while back and was told that the autostick functions this way to a certain degree. It takes some time to shift after you tell it too.
I resolved the problem by installing a JET chip, now it seems to work 100% better, and shifts faster at my command, but there is still a lag.
the 6.1L HEMI's are different, I know that the SRT8 models behave more like a BMW M3 - M5 "sportronic" transmission, and the SRT8's you can fully disable the ESP on the 5.7L HEMI's you can't.
Mr. iNCREDIBLE is offline
Old 07-05-2006, 12:07 PM   #3 (permalink)
MrHappy's Avatar
Car: 2007 Chrysler 300 SRT8
Member Number: 1065
The stock autostick does indeed "auto" shift. You can remove this "feature" with the SuperChips by setting it to paddle-hold mode. Also makes the shifts much smoother and quicker too. IMO, one of the best mods to date for the buck for the 5.7C.
MrHappy is offline
Old 07-05-2006, 12:30 PM   #4 (permalink)
Car: 2005 none 300c
Member Number: 4282
Thanks,
Gates
The system will 'listen' to your commands, but will ignore them when they make no sense. Do this little test, but the car in 'manual' first gear and drive off. As soon as the RPM go above what is sensible, the car will go to second without you commanding it.
Mathijs Kok
Driving a diesel in europe... yeah...
mathijskok is offline
Old 07-05-2006, 01:14 PM   #5 (permalink)
Member Number: 5420
autosick problem
So in the paddle hold mode the 300C will shift on command? Does it still have a failsafe **** point with the superchip?
Thanks
Gates
gates is offline
Old 07-05-2006, 01:23 PM   #6 (permalink)
MrHappy's Avatar
Member Number: 1065
It will stay in gear until it hits the redline limiter and drop back or until you shift it. In theory, you could bounce off the limiter in a single gear all day until the tranny/engine finally went *poof* or you shifted gears.
MrHappy is offline
Old 07-05-2006, 02:06 PM   #7 (permalink)
Member Number: 5420
Thank you for your help! It looks like the superchip will solve my shifting problem.
Thanks,
Gates
gates is offline
Old 07-05-2006, 02:14 PM   #8 (permalink)
MrHappy's Avatar
Member Number: 1065
My pleasure. Be sure to check with our site sponsors for some better than advertised pricing on it! I, myself, got mine from Tbyrne who I know still sells em as do a few other vendors I'm sure. The torque management is well worth it not to mention addressing your shifting woes.
MrHappy is offline
Old 07-05-2006, 08:15 PM   #9 (permalink)
Car: 2005 Midnight Blue Pearlcoat RT w/Daytona R & T int/exh Dodge Magnum
Member Number: 1980
MrHappy is RIGHT ON!!! Superchips is the only way to go....so far.
magnuman is offline
