Old 09-11-2006, 05:39 PM   #1 (permalink)
Jerry M.'s Avatar
Car: 2005 Chrysler 300c
Member Number: 899
Factory Uconnect Install
I finally received my Jet-harness today, ready to get this mod done. I would also like to thank Jaak and Jet-Pilot for all the information regarding this install and the harness. I would also like to thank the guys at MoparSuperCenter.com for offering a great package deal on the parts needed for the install, which was alot cheaper than if I were to use my DC employee discount to buy the parts at my local dealer.
Jet-harness when it arrived
I then used some electrical cloth harness tape to wrap up the wires.
I took off the glove box door to mount the uconnect module. I had read in a post somewhere that the module install to the right of the glove box. Screw holes are already there. (circled in pic)
Screwed in the module in place and ran the wiring behind the radio.
Radio connection is very simple. Unplug main radio connection, Plug that into the Jet-harness, then plug the Jet-harness jumper into the radio.
I then removed the driver side knee bolster panel so I can fish the Jet-harness wire through to the A pillar.
I used some thin but stiff wire to fish up the harness wire up to the mirror harness.
This I think is the trickiest part of the install. Inserting the pins into the appropriate slot in the connector. I followed this pic which shows the aftermarket wire colors mating to the new mirror harness wire colors.
Here was my first connection, white wire with blue stripe to pin #7 which will mate with the black wire with orange stripe on the new mirror harness. I would then hold up the new mirror harness to double check that the 2 wires mentioned do indeed contact one another.
One thing I should mention, not sure what it is called but it locks all the pins in place. I had to lift this up (one click only) so that I could insert all the pins in place. Pins would slide in with no effort until they click in place. Here is a pick with this locking bar lifted slightly. Then just push it back into place when all the wires are inserted.
To make installing the new mirror harness easier, I peeled back some of the door weather stripping, and unscrewed the visor and visor clip so I can pull down a little on the headliner without damaging it. I left the old harness in place. PITA to remove with the push pins in place. I just removed the push pins from the new harness and tucked it up in the headliner. Installed new Uconnect mirror, made connections, put the visor and clip back.
I then used a zip tie to tidy up the remaining jet-harness slack behind the glove box.
Finally, I turn the key... hit the Uconnect button on the mirror....And Sucess...
Jerry M. is offline
Old 09-11-2006, 06:55 PM   #2 (permalink)
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Another excellent step by step How To post with pics. Thanks Jerry & I think this one is also destined as a Sticky in the FAQ/Tech Forum!!!
Rambit
Rambit is online now
Old 09-11-2006, 06:55 PM   #3 (permalink)
HERMINIO's Avatar
Car: TWO 2005 Deep Lava Red 300C's
Member Number: 442
Nice Jerry.
I installed one of mines, "his" yesterday afternoon but impossible to take pictures because of darkness, but did almost the same as you explained except that I removed the old harness including the push pins and installed the new one with their push pins. Not an easy task.
Next weekend I will going with "her".
THX jaak and JetPilot for your effort and help on this one. Many happy LX'ers.
Herminio
2005 300C HIS, DLR, WOOD TRIM, D2S HID, PILLAR SET, AIR DEFLECTORS, LIP SPOILER, TINTING, E&G GRILL, LOWER MESH INSERT, PAINTED ENGINE COVER, VES, AIRHAMMER, UC, UNDERHOOD LIGHT, BFG KDWS 245/55/18, PEDALS SET, CHROME TAIL BEZEL
2005 300C HER, DLR, OEM HID RETROFIT, PILLAR SET, AIR DEFLECTORS, WOOD TRIM, LIP SPOILER, TINTING, OEM CABIN FILTER RETROFIT, E&G GRILL, LOWER MESH INSERT, PAINTED ENGINE COVER, VES, AIRHAMMER, UC, UNDERHOOD LIGHT, BFG KDWS 245/55/18, PEDALS SET, CHROME TAIL BEZEL
HERMINIO is online now
Old 09-11-2006, 07:00 PM   #4 (permalink)
Jerry M.'s Avatar
Member Number: 899
Rambit
Thanks Rambit.. Just trying to help out when ever I can.
Jerry M. is offline
Old 09-11-2006, 07:04 PM   #5 (permalink)
Jerry M.'s Avatar
Member Number: 899
Originally Posted by HERMINIO
Nice Jerry.
Herminio
I'm sure your just as happy as I am with this mod. When I bought the car a couple years ago, this option wasn't a priority of mine since I didn't have a bluetooth phone. Now I can see what I've been missing.
Jerry M. is offline
Old 09-11-2006, 08:36 PM   #6 (permalink)
Member Number: 7149
Yes, Thank you very much for the detail install, this will be very helpful.
A couple of questions...How do you know if you need the Jet-Harness? I understand that some cars will already be wired for U-connect, Is that correct? Where do you get electrical cloth harness tape?
Chase300 is online now
Old 09-11-2006, 08:39 PM   #7 (permalink)
srt8danno's Avatar
Member Number: 1971
Wow, great “how to….” On the the UConnect. I’ll put that in my memory for future use as I’m sure someone will post how to do this mod. Thanks for going to all the trouble to post such a nicely detailed explanation. If I didn’t already have the factory install I would give these directions a try.
srt8danno is offline
Old 09-11-2006, 09:36 PM   #8 (permalink)
Jerry M.'s Avatar
Member Number: 899
Take a look at your mirror harness connector at the bottom of the A pillar. If you already have wires in the spots that I have numbered here, then you will not need the Jet-harness. The Uconnect module harness connector should be behind the glove box area ready to be plugged in.
I bought the electrical cloth tape at Home Depot..
Jerry M. is offline
Old 09-11-2006, 09:42 PM   #9 (permalink)
BobCav's Avatar
Member Number: 2085
Jerry, great write up and pics!! I did mine Fri night with the interior light and a flashlight, so there was no pics to be had, but it was just that easy!! Great job....
Visit my homepage...
BobCav is offline
Old 09-11-2006, 10:04 PM   #10 (permalink)
moddog's Avatar
Member Number: 1965
Great job Jerry like you I did not need the bluetooth I did not even have a cell phone then. But my kids made me get one so this is one mod I will do . I do know what it is like to be on the other end when some one is talking on there cell phone and not paying attention to there driving it hurts !
moddog is offline
