Transmission ratchety/winding noise when shift from N to D or R - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 7 (permalink) Old 03-05-2017, 02:59 PM Thread Starter
Points: 673, Level: 1 Points: 673, Level: 1 Points: 673, Level: 1
Billyjoebob007's Avatar
Car: 2006 Chrysler 300 touring 3.5
When i shift from outta N to D or R trans makes ratchety/winding noise for about 3 seconds. What could be issue and is it something of great concern ?
Billyjoebob007 is offline
post #2 of 7 (permalink) Old 03-05-2017, 03:33 PM
Administrator
Points: 103,870, Level: 1 Points: 103,870, Level: 1 Points: 103,870, Level: 1
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
when did you last check the fluid level?
Watching You Avoiding Me!
Kaiser Bill is offline
post #3 of 7 (permalink) Old 03-05-2017, 04:31 PM Thread Starter
I bought one of those dealership dipsticks but i still dont understand how to get a reading on the level from that chart. What # on the stick would be indicative of a full fluid level ? Also the fluid itself looks really clean.
post #4 of 7 (permalink) Old 03-07-2017, 06:09 AM Thread Starter
Any clues as to what it could be ?
post #5 of 7 (permalink) Old 03-07-2017, 07:09 AM
Administrator
the chart measures temperature vs. level. You need to get a long thermocouple and a cheap electronic temperature gauge to go with it. Shrink tube the thermocouple to the dipstick and you can measure both at once. Use a mm ruler to measure the depth, don't rely on the embossed marks on the dipstick. Just because the fluid looks clean, doesn't mean its correct. I'd start there first
post #6 of 7 (permalink) Old 03-14-2017, 01:58 PM Thread Starter
Finally got around to checking it. readings as follows:
1. Trans pan temp = 89.4
dipstick mark = 30mm
Engine temp = 182
2. Trans pan temp = 98.6
dipstick mark = 33mm
Engine temp = 197
3. Trans pan temp = 104
dipstick mark = 35mm
Engine temp = 212
Sooo from the #3 reading referencing the chart looks like im 5mm low on trans fluid, level should be at about 40mm?
What would be the amount of fluid to add per 5mm or 10mm on the dipstick ? Or just add fluid a little at a time and hope one doesnt add too much ?
post #7 of 7 (permalink) Old 03-20-2017, 04:22 PM
Administrator
its a pain....I overfilled the first attempt I made - luckily I had a dipstick oil sucker. Its the only sane way of doing it or you're in store for a drain & refill. Dribble it in 100ml at a time. I think you'll be in the 200ml area, but its ages since I last did mine, so I'm guessing really
Dash noise cause other than (HVAC blend door) STRaight-up General Discussion on Issues / Trouble Shooting 0 03-03-2017 09:39 AM
05 300c 5.7 transmission wont shift from 3rd gear Christopher L Cabral Power Train 1 07-18-2016 11:59 AM
05' 300C Transmission Trouble - Again PokerGuy General Discussion on Issues / Trouble Shooting 1 01-29-2016 01:45 PM
Transmission fluid warmup times Torian General Discussion on Issues / Trouble Shooting 0 01-29-2016 09:08 AM
Transmission Cooler Location & Water In Trans PokerGuy General Discussion on Issues / Trouble Shooting 4 08-13-2015 10:35 PM
