ABS/BAS/ESP light wont go off on 2007 300 Limited - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 15 (permalink) Old 02-10-2007, 01:41 PM Thread Starter
Points: 4,002, Level: 1 Points: 4,002, Level: 1 Points: 4,002, Level: 1
slyjackson's Avatar
Car: 2007 Chrysler 300 Limited
I have a new 2007 300 limited with less than 600 miles on it. Today I go to get in the car and find out nothing works. Battery died on me. I jumped the car off and all seem well except the "ABS light, ESP light, the traction control light and BAS warning light are on".
These dash warning lights won't go off. I disconnectd the battery hoping that it would reset everything. No luck. I went by the dealer and talked to the service guy and was told to just drive it around some and they will go off. Well i have been driving for hours and they are still on. I am really starting to get pissed.
I'm still not sure what killed the battery, maybe I left a door open or something. All was ok until the battery died, now I have dash warning lights lit all over the place.
Anyone seen this issue before ? If so what was the correction?
Thanks in advance.
2007 - 300 Limited in "Brilliant Black Chrystal Pearl" - Black is truly Beautiful !
My Mod Wish List
[ ] Chrome Startech Mesh Grille
[ ] U-2 35's
[ ] US Speed Rear Spoiler
[x ] Tint Windows
[ ] US Speed Chrome Front bumper cap
[ ] US Speed Chrome Rear bumper cap
[ ] Tinted tails with LED's
[x] My beloved wife has given me permission to do all of this !
Everyone is born a Cowboys fan...Only the smart ones stay that way!
slyjackson is offline
post #2 of 15 (permalink) Old 02-10-2007, 07:09 PM
Elite Contributing Member
Points: 32,157, Level: 1 Points: 32,157, Level: 1 Points: 32,157, Level: 1
srt8danno's Avatar
Not sure what the problem could be. I did a search and found this post from Goose. It sounds like you’ve been doing this already. Did you check all of your fuses to make sure they’re tight? The dealership should then be consulted. Good luck and let us know what you find out.
ESP/ABS Light
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
srt8danno is offline
post #3 of 15 (permalink) Old 02-10-2007, 09:27 PM
Points: 726, Level: 1 Points: 726, Level: 1 Points: 726, Level: 1
Car: 2006 DODGE CHARGER SRT8
This May Help ,get In Car Making Sure Wheels Our Straight Ahead ,start Car, Turn Wheels All The Way To Left And Hold All The Way For 2 Seconds , Turn All The Way Right ,hold For 2 Seconds, Turn And Center Wheels , Turn Off Eng. ,whith Wheels Centered,thats It,you Have Just Reprogramed The Steering Angle That You Messed Up When You Disconected The Battery, This Is Also What You Do For Automatic Up Windows. Dr. Side Down ,up Hold 2 Sec. Down ,then Up Same For Pass. Side
Disconnecting The Bat. Can Cause These Problums, Related To Stearing Angle And Windows All The Way Up Or Down.
Hope This Helps You.
GROGE is offline
The Following User Says Thank You to GROGE For This Useful Post:
Hoppo (08-31-2014)
post #4 of 15 (permalink) Old 02-11-2007, 04:12 AM Thread Starter
slyjackson's Avatar
I will give this a shot. I will post later on the results. Thanks everyone for the replies.
post #5 of 15 (permalink) Old 02-11-2007, 04:25 AM
Points: 10,510, Level: 1 Points: 10,510, Level: 1 Points: 10,510, Level: 1
italianguy63's Avatar
Send a message via Yahoo to italianguy63
Sounds like a dealership issue.
BUT, I was just messing around with the wiring on mine-- maybe this will help. The ESP relay is the on the right side of the rear fuse block in the trunk. It is the bottom left metal relay on the right side. I seem to remember it is in position #45. Swap it with one of the others next to it (same type relays). See if that resolves it. If so-- bad relay.
MC
Bright Silver 2006 300 Touring "El Patron"
Stealth Auto projection headlights, Kayee
mesh Bentley grill, SilverStar/Stealth bulbs,
RAQ radio upgrade, Sirius, auto headlamps,
lip spoiler, de-emblemed and "B"-emblemed,
tint, clear side marker lights, clear K2 LED
Altezza tail-lights, the "Luke" subwoofer
solution in rear armrest, Bob's Blasters dual
exhaust, Eonon 9.2" headrest LCDs, Sony
portable DVD player (center console).
Brilliant!!
italianguy63 is offline
post #6 of 15 (permalink) Old 02-11-2007, 08:16 AM
Points: 1,354, Level: 1 Points: 1,354, Level: 1 Points: 1,354, Level: 1
ppiracing's Avatar
Car: 2007 Chrysler 300C SRT-8
I had the same thing on my '06 SRT8. They told me it was a dirty wheel sensor. Not sure if that's legit, but when I picked the car up the wheels were clean and no lights.
ppiracing is offline
post #7 of 15 (permalink) Old 02-11-2007, 09:11 AM Thread Starter
slyjackson's Avatar
Well guys, I've tried the steering calibration thing. - Did not resolve the problem.
I removed fuse # 11 for 5 minutes- This did not help either.
I swapped the relays in the forward fuse boxes with others of the same value. - No luck.
I did the same with the relays in the aft fuse box with others of the same value. - Still no luck.
But I was successfulin re-calibrating the "auto up" fuction in my windows. This works again.
I guess the dealer will have to deal with this monday, unless you guys have something else to try!!
Thanks for all the replies !!
post #8 of 15 (permalink) Old 02-11-2007, 09:23 AM Thread Starter
slyjackson's Avatar
I just read a thread that says to calibrate the wheel sensor I must be moving slowly. I will go to a parking lot and give this a try. More later.
post #9 of 15 (permalink) Old 02-11-2007, 11:34 AM Thread Starter
slyjackson's Avatar
Well That did not work either. I went to a safeway parking lot and did a full left turn, held it doing a complete circle then straight then did a full right hand turn, held it doing a full circle then straight doing all of this at about 5-10 miles an hour. I then stopped and turn the car off, removed the key, put back the key and started the car and still had all three lights ESP,ABS and BAS.
Have I done something wrong ?
I police cruiser was watching me do all of this but he never came over to ask me what the hell I was doing. Maybe he owns a 300 as well and knew what the deal was....
post #10 of 15 (permalink) Old 02-11-2007, 02:04 PM
The Fix For Stearing Angle Is With The Car Only Stoped Not Moving,jump In Car ,wheels Straight, Start Car, Do Left All Way,hold 2sec. ,right All Way Hold 2 Sec. Bring Back To Wheels Straight Position ,turn Off Car , Restart And Check. Again Car Not Moving, You Can Do This In Your Driveway, Car Stoped In Park.
GROGE is offline
help esp bas abs light on sometimes red airbag light 808_300_regulah Problems / Dealer Service 14 04-27-2015 11:55 AM
Esp/bas Light rawrods Problems / Dealer Service 10 02-21-2012 02:02 AM
esp and bas light on customaudioman Problems / Dealer Service 4 03-19-2010 12:48 PM
ABS-BAS-Trac -control light yamabob Problems / Dealer Service 7 12-08-2009 04:20 PM
abs bas esp U1419 Code beachthrottle Problems / Dealer Service 21 11-19-2009 12:09 PM
