Old 02-13-2007, 03:22 AM   #1 (permalink)
howie0007's Avatar
Car: 2007 Chrysler 300C
Member Number: 10806
300crd And Ipod
Can anyone out there in Chryslerland help with this topic please. I have an 80gig Ipod and want it installed in my 300C to the stereo system. How do I go about it please. I was just told it can't be done. Is this true? I live in the UK. Thanks a lot.
howie0007 is offline
Old 02-13-2007, 04:52 AM   #2 (permalink)
Car: 2006 Chrysler 300
Member Number: 7516
Do a search in the forums and you'll lots of info,
But just to let you know it is possible. i have my 80 gb ipod in my car no problem...
my setup is like this i purchased the harmon kardon drive & play system
which gives you a dash mounted sexy display of everything on your ipod.
and a control module that you can mount where ever you want basically...
i'll post some pics if i get a chance.
the harmon kardon system also charges your ipod at the same time so you never have to worry about charging. mine is tucked away neatly in my glove box... with the control in front of the cig lighter it's quite nice...
the only thing you will have to buy is an AAI-CHY adapter from pac audio
which will give you 2 aux in ports, i got this because i wanted to keep my factory radio....
i've also installed 2 15" 2000 watts peak 1250 rms subs in my trunk lollololol...with a 4000 watts amp. holla if you hemi.
your gonna need two adapters if you want the similar setup....
an L.O.C line output converter. converts the signal from your rear speakers to rca and then straight to your amp.... nice.
the other adapter taps into your rear speaker wires like the one mentioned above. and provides a convieniet signal that runs on a blue wire to power on your amp when you turn on your radio.
be sure to run your harmon kardon system through the dash cig lighter because all the other cig lighter outputs stay on even when the key is out.
which would look quite funny.
so when i put the key in and switch to acc it comes on.... which is what you want...
hope this helps.
Professor is offline
Old 02-13-2007, 05:28 AM   #3 (permalink)
howie0007's Avatar
I really do appreceiate your comments and thanks. Is this setup available in the UK? and is there a website? Thanks again
Old 02-13-2007, 05:33 AM   #4 (permalink)
srt8danno's Avatar
Member Number: 1971
Here are a couple of links that may interest your reading. I would imagine you could get the mopar parts in UK. Hope this helps.
Mopar Ipod Integration Kit Coming Soon!
Mopar Ipod Interface in Australia
srt8danno is offline
