Old 06-24-2007, 04:11 PM   #1 (permalink)
Tork Monster's Avatar
Car: 2006 Chrysler 300C SRT-8
Member Number: 6292
>>How do you remove the console cover???
I am wiring my exhaust cutouts and want to install the switch in the console cover, just ahead of the shifter. I have removed the shift gate bezel, and the two screws unders the rubber mat in front.
What next??
I can't find a thread on this...
Thanks all-
just kruzin' . . . . . Jay
Tork Monster is offline
Old 06-24-2007, 04:43 PM   #2 (permalink)
CplDaugherty's Avatar
Member Number: 5668
Not sure, I'm going to be taking mine out in 2 weeks to do some stuff, let me know if you figure it out.
CplDaugherty is offline
Old 06-24-2007, 05:08 PM   #4 (permalink)
jdiddy101's Avatar
Car: 2005 CHRYSLER 300 limited
Member Number: 8318
CONSOLE-FLOOR
REMOVAL
1. Apply the parking brake.
2. Turn the ignition switch to the On position, apply
the service brakes and place the gear selector
lever into the Neutral position.
3. Turn the ignition switch to the Off position and
release the service brakes.
NOTE: For vehicles equipped with the optional
Automatic Express Up power window feature, calibration
of this feature is required whenever power
to the door module is disrupted. A battery reconnect
procedure must be performed anytime the
battery has been disconnected. (Refer to 8 - ELECTRICAL/
BATTERY SYSTEM - STANDARD PROCEDURE).
4. Disconnect and isolate the battery negative cable.
5. Remove the mat from the cubby bin at the front of
the floor console.
6. Open the lid of the console rear bin and remove the mat from the rear bin.
7. Remove the two screws (1) that secure the front of the console shifter bezel to the console.
8. Using a trim stick unsnap the console bezel from the console
9. Remove the shifter bezel from around the gear selector lever.
10. Remove the three 8 mm bolts (2) from the rear bin that secure the console to the floor panel transmission
tunnel.
11. Remove the two screws (3) that secure the front of the console to the instrument panel.
12. Slide the console rearward far enough to access and disconnect the jumper wire connector (4) from the accessory
power outlet on the underside of the console.
23 - 180 INTERIOR
LX
13. Remove the floor console from the vehicle.
Center Console Cover with DVD
1. Open console lid.
2. Remove side covers.
3. Remove six screws.
4. Remove console cover.
INSTALLATION
1. Position the floor console into the vehicle rearward far enough to access and reconnect the jumper wire connector
(4) to the accessory power outlet on the underside of the console.
2. While holding both sides of the console at the front carefully engage the ears at the front of the console to the
slots (5) at the lower instrument panel.
3. Locate the two alignment holes at the front of the console over the two alignment pins on the instrument panel.
4. Engage the locating pin on the underside of the console rear bin into the slot in the top of the floor panel transmission
tunnel.
LX
INTERIOR 23 - 181
5. Install and tighten the two screws (3) that secure the front of the console to the instrument panel. Tighten the
screws to 3 N·m (23 in. lbs.).
6. Install and tighten the three 8 mm bolts (2) into the rear bin that secure the console to the floor panel transmission
tunnel. Tighten the bolts to 5 N·m (40 in. lbs.).
7. Position the console shifter bezel (4) over the gear
selector lever.
8. Position the tabs on the underside of the console
shifter bezel into the holes in the floor console.
9. Install and tighten the two screws (1) that secure
Tighten the screws to 3 N·m (23 in. lbs.).
10. Position the mat (5) into the console rear bin with
the curved edge oriented forward in the vehicle.
11. Position the mat (2) into the cubby bin at the front
of the floor console.
12. Firmly push shifter trim ring (4) down the to position
it to the gear selector.
13. Place the gear selector lever into the Park position.
to the door module is disrupted. A battery reconnect procedure must be performed anytime the battery has
been disconnected. (Refer to 8 - ELECTRICAL/BATTERY SYSTEM - STANDARD PROCEDURE).
14. Reconnect the battery negative cable.
1. Install console cover.
2. Install six screws.
3. Replace side covers.
Modification List
[X] Factory Nav
[X] In-motion Hack
[X] Tint 20% back 35%front
[X] Factory U-connect
[X] Leather armrest
[X] Startech grille
[ ] HID's
[ ] JL-2 10w7's
[ ] Backup Camera
[ ] Navtogo
[X]Universal Air Suspension
jdiddy101 is offline
Old 06-24-2007, 05:18 PM   #5 (permalink)
Member Number: 6292
MANY THANKS GUYS!!!
I don't know how I did work on my previous cars without a forum like this...
Oh, I remember now... I did it wrong, then did it over. SOP
Thanks again!!
Old 06-24-2007, 06:53 PM   #6 (permalink)
Member Number: 232
Here are the pics from the service manual I had saved awhile ago. You should download the service manual. It is priceless!
how-do-you-remove-console-cover-center-console-pg-1.jpg  how-do-you-remove-console-cover-center-console-pg2.jpg  how-do-you-remove-console-cover-center-console-pg3.jpg
joey is offline
Old 06-24-2007, 07:10 PM   #7 (permalink)
Member Number: 6292
Thanks Joey!
I found that link on the LXforums right after I removed the console with the help of the instructions I received above.
This link should be posted here again!
