Old 08-24-2007, 02:33 PM   #1 (permalink)
SBK
Car: 2005 Chrysler 300c
Member Number: 12843
Switched Power in Front Fusebox?
I have no idea where my test meter is
I am out there right now looking to piggyback fuse something in the front fuse box (2005 300c) so I can have a line with switched power.
I don't want to go off the cig lighter line anymore because I have a few things on it already.
Anyone know an empty slot or a fuse I could piggyback in the front fuse box?
I searched a bunch and only came up with someone saying #14 up front would be empty and I could use that. However there is a 20 fuse in there and the manual says it is for the PCM (if memory from 2 minutes ago is correct)
I figured I would ask you guys. Thanks fellas.
SBK is offline
Old 08-24-2007, 03:20 PM   #2 (permalink)
1fastsedan's Avatar
Member Number: 5972
Trader Rating: (4)
I haven't checked every single one, but out of the 10 or so we checked #14 was the only switched fuse we found in the under the hood fuse panel. Yes, its a PCM fuse. No, it hasn't been a problem piggy-backing off of it.
1fastsedan is offline
Old 08-24-2007, 03:52 PM   #3 (permalink)
SBK
Perfect! Thank you. I am going to run to autozone to pick up a mini piggyback fuse.
Thanks a ton.
SBK is offline
