Old 10-22-2007, 10:52 AM   #1 (permalink)
1fastfox
Car: 2006 chrysler 300C
Member Number: 12733
300 Hemi C Stalling?
I am posting this for my dad who has a 2006 300C, he has been experiencing the car stalling and this lightning bolt like warning light on the dash lighting up. We tried disconnecting the battery and it worked for one day then it started stalling again. It has a aftermarket chip in it, but that has been on there for a few months now. We are going to try to remove the chip to see if this makes a difference. The only other mods is a Mopar CAI nad Corsa Exhaust. Any help would be greatly appreciated.
Thanks Chris
1fastfox is offline
Old 10-22-2007, 12:29 PM   #2 (permalink)
crhemi
crhemi's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 3307
How many miles? Have you changed plugs? Have you kept the filter (Mopar CAI) cleaned and oiled?
crhemi is offline
Old 10-22-2007, 12:36 PM   #3 (permalink)
jimhild
jimhild's Avatar
Car: 2005 Satin Jade-all options 300C
Member Number: 836
Thumbs down
With our 2005 300C we had a random, intermittent stall problem. Generally, from a stop for a traffic light or turn signal and the stall occurred when you tried to accelerate. More often than not it was during a turn when the stall occurred, but many times it was just straight acceleration from a stop.
You had to let up on the throttle, allow the engine to catch and continue. No dealer every found a problem or resolution.
Very concerning as you never know if the power you need will be there or not.
Susan & Jim Hildebrand
2005 300C Satin Jade
jimhild is offline
Old 10-22-2007, 01:44 PM   #4 (permalink)
1fastfox
My Dad says it happens when he comes to a stop then tries to accelerate or if he tries to make a left hand turn. The cat only has less than 10,000 miles on it and it is well maintained. The plugs where never replaced and the filter should be in good condition, since the manufacturer says to re oil and clean evry 100,000 miles. Should I check the filter? Could the chip be making this happen? My dad wants to bring it back to the dealer so do you think we should remove the chip first? According to the chip manufacturer it should not void the warranty.
Thanks chris
1fastfox is offline
Old 10-22-2007, 06:21 PM   #5 (permalink)
1fastfox
Well ided to take the chip out to see if that what was causing the problem and since I have taken it out the stalling has stopped. My dad can definately tell the difference with the chip out. We noticed the chip was alittle wet so I am wondering when we washed the car rthe other day if we might have got the chipt wet. We are going to drive the car for a few days and then reinstall the chip to see if the problem comes back.
Chris
1fastfox is offline
Old 10-22-2007, 08:03 PM   #6 (permalink)
TZ-MI
Car: 2005 CHRYSLER 300C
Member Number: 13261
Thanks Chris
Is the car under 36,000 miles and if so take it to the dealer. The codes shoukd be locked. Should being the key word. Contact me if you don't get help as I work for a dealer.
TZ-MI is offline
Old 10-22-2007, 10:14 PM   #7 (permalink)
doodie300c
doodie300c's Avatar
Car: 2005 Chrysler 300c
Member Number: 1713
try sending the chip back and get a different one.
doodie300c is offline
Old 10-23-2007, 07:46 PM   #8 (permalink)
TZ-MI
If you have anything that is modifying the throttle body it will potentially set off the lightning bolt. An aftermarket air filter can do the same. Is your dealer working with you or not?
TZ-MI is offline
Old 10-25-2007, 05:43 AM   #9 (permalink)
1fastfox
Since we removed the chip the problem has totally gone away. The chip and CAI have been on the car now for over a year now and only till now did we have problems. I am hoping it was only that the chip got wet that it was causing this problem. I will let you know what happens when we put the chip back in. When we installed the CAI we were told by the dealer that as long as we use Mopar parts, it won't affect the warranty.
Thanks Chris
1fastfox is offline
Old 10-25-2007, 05:57 AM   #10 (permalink)
Chinajohnny
Chinajohnny's Avatar
Car: 2006 China made Chrysler 300c 5.7 L Hemi
Member Number: 12469
Send a message via Skype™ to Chinajohnny
I also had this once.
Magnaflow exhaust
Jet Chip
Airaid
Jet Throttle spacer
180 degr. thermostat
Predator in but no tune yet due to difficulties
Chinajohnny is offline
