Old 12-15-2007, 10:53 AM   #1 (permalink)
PureEnjoyment's Avatar
Car: 2008 Chrysler 300C SRTdesign
Member Number: 6502
Send a message via AIM to PureEnjoyment
Anyone else having probs with Diablo and limp mode???
So I really like my predator, but WAY to often when I gun it and the revs go up in the 6000 range it just cuts out and goes into what I think is "limp mode". Then I have to coast somewhere safe off to the side of the rode, shut my car off and then turn it on before I can drive again. Its such a pain in the butt! It has probably happened about 6 times since I've had the predator. I just dont understand what is going on???? btw I have a late model 2005 300c.
PureEnjoyment is offline
Old 12-15-2007, 11:17 AM   #2 (permalink)
300C_Chris's Avatar
Member Number: 10200
Have you used the Predator to check for codes.
Mods
Diablo Predator 91 octane CIA tune
AFE Stage 2 CAI
Magnaflow Highflow Cats
Corsa Catback Exhuast
Motorad 4128 180 Tstat
22Elite Leather Console Cover
SRT Floor Mats
300C_Chris is offline
Old 12-15-2007, 11:29 AM   #3 (permalink)
Sunrider's Avatar
Member Number: 12647
Did you raise your shiftpoint settings and if so did your raise you rev limiter?
Sunrider is offline
Old 12-15-2007, 11:39 AM   #4 (permalink)
Member Number: 6502
Originally Posted by Sunrider View Post
Did you raise your shiftpoint settings and if so did you raise you rev limiter?
I just used the canned tune for 93 octane and a CAI
Old 12-15-2007, 11:47 AM   #5 (permalink)
Sunrider's Avatar
If you have not done so already.. load the stock tune and take her out on the road to be sure its nothing else thats causing this to happen.
Sunrider is offline
Old 12-15-2007, 11:51 AM   #6 (permalink)
topfuel67's Avatar
Car: 2006 Chrysler 300c SRT8
Member Number: 9144
I really like the ESP off with the diablo, but found out that makes mine go into limp mode if I make a u-turn or another sharp turn like pulling out of a low driveway.
Mods:
Diablo
Corsa Exhaust
185 T-stat
275/40/20s
AFE Stage II CAI
Mopar Grill
topfuel67 is offline
Old 12-15-2007, 01:48 PM   #7 (permalink)
stealthsrt8's Avatar
Member Number: 7491
even if you have not raised the shift points, be sure to raise the rev limiter.
2006 Brilliant Black 300CSRT
stealthsrt8 is offline
Old 12-15-2007, 03:27 PM   #8 (permalink)
Car: 2008 Jeep Grand Cherokee SRT8
Member Number: 14202
Right, you have to raise the rev limiter. Kick it up 300-400rpm.
Mike Levy
08 Black Grand Cherokee SRT8
9/07 build
Mike_Levy is offline
Old 12-16-2007, 10:24 AM   #9 (permalink)
Member Number: 7012
I had the same problem when i missed a gear change or was doing a burnout. I have the Autostick hold gear option enabled and when i raised the rev limiter to 6800 and higher shift points the car would always go into limp mode when it got anywhere near the limiter. Went back to the stock 6400 redline and havent had a problem since.
Never once had that problem when i had the rev limit set to 6800 and higher shift points with the transmission Auto-upshifting...only when transmission was set to hold the gears.
Konvict is offline
