What are symptoms of bad tie rods? - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 4 (permalink) Old 01-05-2008, 02:11 PM Thread Starter
Points: 9,560, Level: 1 Points: 9,560, Level: 1 Points: 9,560, Level: 1
gbracer's Avatar
Car: 2005 Chrysler 300c
How do you know if your tie rods are bad? Will the dealer let you know when you go in for service? What kind of tests could I perform to check them?
gbracer is offline
post #2 of 4 (permalink) Old 01-05-2008, 02:25 PM
Points: 37,423, Level: 1 Points: 37,423, Level: 1 Points: 37,423, Level: 1
CUEBALL's Avatar
Clunking noises, wandering, and overall poor handling..... increased tire wear...
By taking weight off front end with jack, check play side to side and top to bottom of wheels. If knuckle of tie rods have play, it is a pretty good indicator it is time to replace. Sometimes if tie rods bad, hitting a bump on highway will affect steering and feel sway.
FORUM SUPER MODERATOR from 2007-2012; Car sold Sep 2011
MODS: 22elite Console cover, Formula One 35%, Blastin Bob's 5db resonator delete, KW V2's, Hotchkis sways, 3-Piece Intro 311 22's, Stoptech slotted rotors(Zeckhausen), Fenders rolled, TZ wingless grille, SS Braided brake lines, ATE super blue DOT 4 fluid, SPC camber kit, Headlight Armor 50% tint, Jonstintedtails.
CUEBALL is offline
post #3 of 4 (permalink) Old 01-05-2008, 02:32 PM
Elite Contributing Member
My first guess is to jack the car up, and grab the tire in the 9 & 3 O'Clock position and see if it wiggles or makes noises.
Not sure how to test if the inner our outer tie rods are bad.
Here are some Youtube vids of bad tie rods.
Inner Tie Rod
YouTube - Inner Tie Rod Test
Outer Tie Rod
YouTube - shot tie-rod
YouTube - 1999 Audi A4Q Tie-Rod
Replacing Outer Tie Rod
YouTube - Replacing A Tie Rod End on a 2000 Dodge Dakota
YouTube - Changing Tie Rod Ends
joey is offline
post #4 of 4 (permalink) Old 01-05-2008, 04:53 PM
Points: 562, Level: 1 Points: 562, Level: 1 Points: 562, Level: 1
Car: 2005 Chrysler 300C 5.7
I just replaced my inner tie rods. Thats seems to be which parts are going bad cause i had to call all over the U.S to get two and there were only three left all on back order. Don't let them tell you that the whole rack/pinoin is bad the reason they do that is to fix the problem, because the rack/pinoin comes with the inner tie rods. They tried doing that to me. My 300C would shake really bad when braking and the steering wheel would shake or vibrate while driving, and would turn akward. The tie rods were about 59.00/piece and to change should only run about 150-200.00 cause they have realign the car after. If you do have to change rack/pinoin its about 590.00 just for the part. Well hope this helps.
rov.mclean is offline
Front end clunk----turns out it was tie rods and radius rods Cool_V_300C Suspension/Handling Modifications 24 05-30-2013 03:10 AM
Tie Rods Help flashman Suspension/Handling Modifications 4 04-23-2009 12:13 PM
Tie Rods (Driving symptoms) kobe8 General Discussion 8 10-31-2008 04:31 PM
Bad Tie Rods - Symptoms harv1000 Suspension/Handling Modifications 12 07-30-2008 11:40 AM
tie rods 2005 Big Body Custom Wheels & Tires 2 06-21-2007 06:03 AM
