Originally Posted by mouserider
Well, it was a wild guess considering that there is a setting to turn on/off SmartBeam despite being able to turn that on/off at the steering wheel level, just gives you the ability to turn the "smart" part on/off.
Usually if I get a sensor blinded situation, I'm SOOL for cruise control until either the snow melts or I stop and clean the sensor.
Well, we were both half-right. Apparently there is a setting to enable/disable the ACC, its just that the setting can only be adjusted at the dealer.
When the tech looking into the Cruise Control settings with thier diag tool, it said it was in "Standard" mode - which apparently doesn't enable ACC if you have that option - it probably defaulted to "Standard" by default as you metioned after the flash.
So the tech changed it to the other setting (I don't know the name), and now I have both ACC and Normal cruise control modes (switch between them by press and hold the button for >1 sec).
So, anyone getting the flash for the normal cruise mode for ACC-equiped 2008 300c's should make sure the tech changes the ACC mode from "Standard" to the ACC enabled mode.
