Old 04-16-2008, 12:17 PM   #1 (permalink)
bigsnake's Avatar
Member Number: 10476
Specifications: Fluid capacities
These will be updated as needed. If you see something that needs changing feel free to add!
SPECIFICATIONS - FLUID CAPACITIES
DESCRIPTION
SPECIFICATION
Fuel Tank - V6 Engine 68 L (18 gal.)
Fuel Tank - V8 Engine 72 L (19 gal.)
Engine Oil* - 2.7 L 5.7L (6.0 qts.)
Engine Oil* - 3.5 L 5.7L (6.0 qts.)
Engine Oil* - 5.7 L 6.6 L (7.0 qts.)
Engine Oil* - 3.0 L Diesel 8.5 L (9.0 qts.)
Engine Oil* - 6.1 L 6.6 L (7.0 qts.)
Cooling System - 2.7 L** 9.2 L (9.7 qts.)
Cooling System - 3.5 L** 10.0 L (10.6 qts.)
Cooling System - 5.7 L** 13.8 L (14.6 qts.)
Cooling System - 6.1 L** 14.0 L (14.8 qts.)
Cooling System - 3.0 L Diesel** 13.2 L (14.0 qts.) *(includes filter)
*(includes heater and coolant recovery bottle filled to MAX level)
AUTOMATIC TRANSMISSION
Service Fill - NAG1 5.0 L (10.6 pts.) Overhaul Fill - NAG1 7.7 L (16.3 pts.)♦
Service Fill - 42RLE 3.8L (4.0 qts) Overhaul Fill - 42RLE 8.3L (17.6 pts)♦
♦Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary.
TRANSFER CASE
MS140 0.6L (1.3 pts.)
AXLE - FRONT
175MM FIA Axle 600 ml (0.63 qts)
AXLE - REAR
198 MM RII Axle 1.4L (1.5 qts.)
210 MM RII Axle 1.6L (1.7 qts.)
215 MM RII Axle 1.6L (1.7 qts.)
RECOMMENDED FLUIDS, LUBRICANTS AND GENUINE PARTS
ENGINE
Component Fluids, Lubricants and Genuine Parts
Engine Coolant Mopar ® Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology)
Engine Oil (2.7 Liter) Use API Certified engine oil. SAE 5W-20 is recommended. Refer to the engine oil fill cap for the correct SAE grade meeting DaimlerChrysler Material Standard MS-6395.
Engine Oil (3.5 Liter) Use API Certified engine oil. SAE 10W-30 is recommended. Refer to the engine oil viscosity chart for the correct SAE grade meeting DaimlerChrysler Material Standard MS-6395.
Engine Oil (5.7 Liter) Use API Certified engine oil. SAE 5W-20 is recommended. Refer to the engine oil fill cap for the correct SAE grade meeting DaimlerChrysler Material Standard MS-6395.
Engine Oil 6.1 Liter) Use API rated SL/CF full synthetic engine oil, such as Mobil 1® . SAE 0W-40 is recommended.
Spark Plugs Refer to the Vehicle Emission Control Information label in the engine compartment.
Oil Filter (2.7 Liter) Mopar ® 05281090 or equivalent.
Oil Filter (3.5 Liter) Mopar ® 05281090 or equivalent.
Oil Filter (5.7 Liter) Mopar ® 05281090 or equivalent.
Oil Filter (6.1 Liter) Mopar ® 05281090 or equivalent.
Oil Filter 2008 (5.7),(6.1) 4884899AB
Fuel Selection (2.7 Liter) 87 Octane
Fuel Selection (3.5 Liter) 89 Octane
Fuel Selection (5.7 Liter) 89 Octane
Fuel Selection (6.1 Liter) 91 Octane
CHASSIS
Automatic Transmission Mopar ® ATF+4 Automatic Transmission Fluid or equivalent.
Brake Master Cylinder Mopa ® DOT 3 and SAE J1703 or equivalent should be used. Use only recommended brake fluids.
Front Axle API Certified GL-5 SAE 75W90 Gear Lubricant or equivalent.
Power Steering Reservoir Mopar ® Power Steering Fluid + 4, Mopar ® ATF+4 Automatic Transmission Fluid or equivalent.
Rear Axle API Certified GL-5 SAE 75W140 Synthetic Gear Lubricant or equivalent.
Transfer Case Mopar ® Transfer Case Lubricant LX, P/N 05170055EA, or equivalent.
CAPACITIES
DESCRIPTION
U.S.
Metric
Fuel (approximate)
2.7 Liter Engines (87 Octane) 18 gallons 68 liters
3.5 Liter Engines (89 Octane) 18 gallons 68 liters
5.7 Liter Engines (89 Octane) 19 gallons 72 liters
6.1 Liter Engines (91 Octane) 19 gallons 72 liters
Engine Oil-With Filter
2.7 Liter Engines (SAE 5W-20, API Certified) 6.0 qts. 5.7 liters
3.5 Liter Engines (SAE 10W-30, API Certified) 6.0 qts. 5.7 liters
5.7 Liter Engines (SAE 5W-20, API Certified) 7.0 qts. 6.6 liters
6.1 Liter Engines (Mobil 1 0W40, API rated SL/CF full synthetic engine oil) 7.0 qts. 6.6 liters
Cooling System *
2.7 Liter Engines (Mopar ® Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent. 9.7 qts 9.2 liters
3.5 Liter Engines (Mopar ® Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent. 10.6 qts 10.0 liters
5.7 Liter Engines (Mopar ® Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent. 14.6 qts 13.8 liters
6.1 Liter Engines (Mopar ® Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent. 15.2 qts 14.4 liters
* Includes heater and coolant recovery bottle filled to MAX level.
SRT8 OPENS A CAN OF
300C SRT8 _ Charger R/T
Mods:
Mopar CAI
Centric Posi-Quiet brake pads
Stealth SRT8 Pedals
Mopar Locking Gas Cap
Billet Tech Catch Can
Motorad 180 T stat
bigsnake is offline
Old 04-17-2008, 06:48 AM   #2 (permalink)
3Shizzle's Avatar
Car: 2007 Chrysler 300
Member Number: 13939
cool. thanks! i made a print out so i dont have to keep checking my manual.
myspace.com/troyseecharran
3Shizzle is online now
Old 04-18-2008, 08:19 PM   #3 (permalink)
Hemi 7's Avatar
Member Number: 17383
Fluid Levels
Thanks very helpful
Hemi 7 is offline
