300C tie rod problems - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
post #21 of 43 (permalink) Old 11-01-2009, 11:08 AM
Elite Contributing Member
Originally Posted by leonethompson View Post
This happened to me yesterday. Failed just as I got home so i was safe.
Any handling issues or noises before this happened?
joey is offline
post #22 of 43 (permalink) Old 11-01-2009, 11:17 AM
bruno's Avatar
That's horrible. I don't even want to think of what could have been.....
bruno is offline
post #23 of 43 (permalink) Old 11-01-2009, 12:09 PM
Points: 3,547, Level: 1 Points: 3,547, Level: 1 Points: 3,547, Level: 1
leonethompson's Avatar
Car: 2007 Chrysler 300c
Send a message via MSN to leonethompson
Yes, there was a small rattle in the front end. I've been driving VERY cautiously since I first heard the rattle, thought it was the suspension. looks like waiting til the weekend was too long of a wait! Seriously though, it's amazing that such a small looking joint holds these wheels in sync. I might have to design then have someone build something different to use..
leonethompson is offline
post #24 of 43 (permalink) Old 11-01-2009, 01:35 PM
How long did you hear the noise?
You are the first person I know of that has had the outer tie rod break apart. From your ID info, it appears your car is still under warranty. Any other mods? Knowing how squirrelly some dealers are, I can just image them trying to blame it on your drilled rotors
joey is offline
post #25 of 43 (permalink) Old 11-01-2009, 05:15 PM
Points: 2,942, Level: 1 Points: 2,942, Level: 1 Points: 2,942, Level: 1
Car: 2007 Chrysler 300C Long Wheel Base
I have a 2007 300c w/21k miles. I have been experiencing the vibration on the left front wheel after alignment and 2 full wheel balancing sessions(second time for new tires). The car is pulling left, as is common for these cars. When breaking at speeds of 60-80mph (for traffic cams) i get the vibration normaly associated with a wheel in balancing... as previosly stated, 2 balancing sessions later... same sh*t different tires.
SO, could you please post all of the symptoms associated with tie rod failure? I want get the car up to par before the rod is on the floor...
As I drive through the valley of the shadow of ricecookers, I shall fear no riced turbo, for thy HEMI is with me..... Bright Silver 2007 Chrysler 300C 5.7L Long Wheel Base, Yokosuka, Kanagawa, Japan 239-0844(Fleet Activities Yokosuka, Japan) US NAVY, FPO, AP 96349
hectoralex is offline
post #26 of 43 (permalink) Old 11-02-2009, 08:04 AM
There was no vibration in my case. You may want to check that your rotors are not warped. I had to grab these drilled rotors at 100 000km because my other ones were warped. The vibration was subtle but very freakin annoying.
For the tie rod end, it was just a slight rattle that was present, it seemed just like when the suspension was going in my previous car so I figured thats what it was. There was nothing else that could lead me to beleive otherwise until it failed. No handling issues, no vibration, everything felt the same. Hope all works out for you. I'm going to call the dealership and see what they say about this issue.
post #27 of 43 (permalink) Old 11-04-2009, 07:42 PM
Points: 30,217, Level: 1 Points: 30,217, Level: 1 Points: 30,217, Level: 1
kevenj's Avatar
Originally Posted by 2005_300c View Post
is there a better than OEM product we can all buy
Napa part # 269-3215 is greasable (unlike OE) and has a lifetime warranty. retails for about $57.00
kevenj is offline
post #28 of 43 (permalink) Old 11-05-2009, 06:00 AM
Thanks, I find it disturbing that the OE one isn't greasable too. I design trucks and every moving component/assembly that I design has grease nipples added to it, so I'm used to seeing it, freaked me out when I didn't see them on the tie rod ends. I called Napa down here and they quoted me $140 PER SIDE. I verified that it was only for the tie rod end and they confirmed, I hung up. I hope that nobody has to go through what I went through, this literally could've been deadly if it failed 10 minutes prior to when it did.
post #29 of 43 (permalink) Old 11-05-2009, 09:39 AM
kevenj's Avatar
$140 per side? I wonder if they were quoting the outer and inner tie rod ends? I wouldn't think there would be that much difference between the U.S. and Canada. The Napa store I work at sells it for $57.19. It's a couple bucks cheaper online:
NAPAONLINE
kevenj is offline
post #30 of 43 (permalink) Old 11-05-2009, 12:20 PM
Points: 65,145, Level: 1 Points: 65,145, Level: 1 Points: 65,145, Level: 1
IMPORTEDFROMDETROIT's Avatar
Car: 2011 Dodge Challenger 5.7
replaced mines at 108,000
___________________________________________
2011 DODGE CHALLENGER R/T
IMPORTED FROM DETROIT
IMPORTEDFROMDETROIT is offline
22s - TIE ROD PROBLEMS! LAIDBACKC Performance Wheels & Tires 74 07-13-2011 02:17 AM
Inner Tie Rod Ends 300C JAMES300 General Discussion 1 06-09-2010 08:59 AM
how can u tell if tie rod is bad 05coolvanilla General Discussion 8 03-11-2010 02:41 PM
Tie Rod Help bund Suspension/Handling Modifications 0 07-29-2009 08:46 AM
tie rod question e-ville Performance General Discussion 2 05-04-2009 03:52 AM
