What's the correct oil and temp. settings for the 5.7 Hemi??
I have a 300C AWD with a 5.7 Hemi.
Just had my oil changed and thought I would check my oil pressure digital read out. I notice the oil pressure when fully warmed up and sitting at an idle reads between 16 to 20lbs. Is that normal presure for the car at idle?
When at highway speed the oil pressure goes up to 45 to 50lbs.
Also the temp. gauge reads 210 degrees at normal highway speeds...seems high, but the idiot gauge on cluster just is always in the same position at the half way mark.
Your stock Tstat doesn't open fully until 203 F, so the coolant temperature looks completely normal. Oil temps will be above that by quite a bit, but I haven't paid attention to idle and rolling oil pressure. But I'm sure someone has...
Car: 2007 Chrysler 300C SRT Design & 1967 Plymouth Belvedere II
Member Number: 17559
210 is normal with stock thermostat. I get 52 psi oil pressure at 70 mph. Not sure about oil pressure at idle as I haven't specifically looked at it, but 16-20 psi sounds normal as well.
Good to know my temp is running normal at 210 degree.....look forward to anyone's advice on the idle oil pressure issue?
Gary
You don't have an oil pressure "issue" - - your oil pressure is completely normal too; you only need 6 or 7 psi at idle to keep everything lubricated. As the engine RPM increases, so does the oil pump RPM - so you get more pressure when the engine is running faster, which is when you need it.
