How to reset low tire pressure warning indicator? - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 10 (permalink) Old 01-10-2010, 11:59 AM Thread Starter
Points: 1,028, Level: 1 Points: 1,028, Level: 1 Points: 1,028, Level: 1
Car: 2010 Chrysler 300 SRT8
The cold weather caused my low tire pressure light to go off. I put air in the tires and the pressure is correct. The monitor shows the correct pressure for all four tires, but the left front is blinking and light won't go off. Is there a secret to turning off the warning indicator?
TampaSRT is offline
post #2 of 10 (permalink) Old 01-10-2010, 12:12 PM
Points: 37,638, Level: 1 Points: 37,638, Level: 1 Points: 37,638, Level: 1
It should sort it's self out when you drive the car, it might take a few miles.
ivanford is offline
post #3 of 10 (permalink) Old 01-10-2010, 12:18 PM Thread Starter
That is what I read in the manual, but it came on yesterday and still hasn't went out. I will give it another day of driving and off to the stealership if it doesn't resolve itself. Thanks for the reply.
TampaSRT is offline
post #4 of 10 (permalink) Old 01-10-2010, 12:20 PM
Administrator
Points: 463,600, Level: 1 Points: 463,600, Level: 1 Points: 463,600, Level: 1
Rambit's Avatar
Car: 2005 300C SRT8
It can take up to 10 minutes of driving at least 15 mph to relearn.
Bernie
Headlights etc...
Rambit is offline
post #5 of 10 (permalink) Old 01-13-2010, 04:56 AM
TSB/Recall Forum Moderator
Points: 224,245, Level: 1 Points: 224,245, Level: 1 Points: 224,245, Level: 1
ResumeSpeed's Avatar
Car: 2008 Fast, really really fast. Jeep!!
One more thing to try if you are still having the issue - temporarily run the pressure up ~5-7 lbs above the placard setting, then return it back to normal. Then drive around as Bernie stated.
ResumeSpeed is offline
post #6 of 10 (permalink) Old 01-13-2010, 07:43 AM
Points: 11,603, Level: 1 Points: 11,603, Level: 1 Points: 11,603, Level: 1
MM-JAPAN's Avatar
Car: 2007 Chrysler 300C
I had this problem also when the cold weather hit here but I had also just put NITROGEN in the tires but the warning indicator went away after a few min. of driving and has returned. It does bring up a question I have though, are the TMPS run on batteries? Do they blink when the battery is going dead and you have to replace them?
Mods:
x AFE Stage II CAI
x 300C UltimatePedals
x Tinted Windows
x Interior BLUE LEDs
x Billet Tech Everything
x LED Tail Lights
x KW V1 Coilovers
x Cargo Molded Tray
x Mesh Grill
x IPOD Interface Kit
x ETC Toll Road Payment Device (Japan)
x NITROGEN filled Tires
x VIP300Inc Front/Rear Lips
x Hotchkis Front/Rear Anti-Sway Bars
x Clear Bumper Lights
x Diablo Predator - 93 Oct & CAI tune
x GREEN LED Head & Fog Halos
x 8000K Head & Fog HIDs 55w
x CORSA exhaust
x KOOKS LT Headers & HI-Flow CATs
MM-JAPAN is offline
post #7 of 10 (permalink) Old 01-13-2010, 08:00 AM Thread Starter
I set it to 35 and it went out after a few miles, good suggestion. I guess once it comes on it has to go above the recommended pressure before it goes out. I brought it back down to 31 and all is well. Thanks again.
TampaSRT is offline
post #8 of 10 (permalink) Old 01-13-2010, 08:18 AM
Administrator
Rambit's Avatar
Car: 2005 300C SRT8
Actually there are batteries in the TPM's, but apparently they're not replaceable.
Originally Posted by Service Manual
On vehicles equipped with Tire Pressure Monitoring (TPM), one tire pressure sensor (6) is mounted to each wheel (5) in place of the traditional tire valve stem. Each sensor has an internal battery that lasts up to 10 years. The battery is not serviceable. At the time of battery failure, the sensor must be replaced.
Bernie
Rambit is offline
post #9 of 10 (permalink) Old 01-12-2016, 02:00 PM
Users Awaiting Email Confirmation
The only way to replace the battery in the tire pressure sensors is to replace the sensor. The dealer will tell you the sensor then needs to be programmed for that vehicle and could cost up to $250 per wheel.
sandiego1969 is offline
post #10 of 10 (permalink) Old 01-12-2016, 07:35 PM
Points: 82,176, Level: 1 Points: 82,176, Level: 1 Points: 82,176, Level: 1
MADDOG's Avatar
Re-programming is not necessary if you purchase the correct OEM replacements, or some Dorman models, that broadcast at the correct frequency for year vehicle.
Michael
MADDOG is offline
Low tire pressure light? jt321 Problems / Dealer Service 23 11-05-2015 12:28 PM
Tire pressure sensor reset BDMCP Custom Wheels & Tires 6 04-04-2014 07:27 PM
Low pressure warning retard power? Deuuuce Performance General Discussion 6 05-24-2006 09:07 AM
Low tire pressure warning icon stays on Brewdude Problems / Dealer Service 2 01-26-2006 07:09 PM
On Board Tire Pressure Indicator Rich General Discussion 3 07-31-2005 10:20 PM
