How do u replace the side rear view mirror on Chrysler 300 ? - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 3 (permalink) Old 04-17-2010, 09:03 PM Thread Starter
Points: 2,758, Level: 1 Points: 2,758, Level: 1 Points: 2,758, Level: 1
I need to replace my passenger side view mirror on my 2006 Chrysler 300 Touring. If anyone has any input that would be greatly appreciated. Thanks.
DIGITALGRAVEL is offline
post #2 of 3 (permalink) Old 04-17-2010, 10:44 PM
Points: 1,200, Level: 1 Points: 1,200, Level: 1 Points: 1,200, Level: 1
cyborgasm's Avatar
Car: 06 Chrysler 300
Hope its ok to link to a fellow site but theres a fairly detailed description over on charger forum
removing the side mirrors - Dodge Charger Forums
hope that helps.
these should be similar if not exactly the same for 300, Charger and the grocery getter Magnum.
cyborgasm is offline
post #3 of 3 (permalink) Old 04-19-2010, 11:22 AM
Points: 3,568, Level: 1 Points: 3,568, Level: 1 Points: 3,568, Level: 1
MCORegal's Avatar
Car: 2007 Chrysler 300C SRT
I just did this friday on my 2007 SRT. The steps are similar, but slightly different from the link posted. From memory:
There were 5 or 6 of the push pins, I took a philips screwdriver and pressed the center in. They came out easily after that. To reinstall, simply push the pin the other way (so the head sticks up).
There were about 6 philips screws. One near the handle (hidden) another below the armrest (hidden), one on the door hinge side of the door and three or four at the very bottom of the door trim.
Once all the above are removed, simply lift from the bottom (pull toward you) and the door panel pivots out. Remaining behind is a rubber weatherstrip system that can be pushed out of the way to get to the mirror bolts. I believe the bolts are 8mm.
To remove the mirror, you also need to remove or really loosen the outer window trim piece. There is a torx head on the end of the door that holds it in place. Once removed, simply lift the molding slightly and it will pop up enough to allow mirror replacement. I believe I did this with the window in the down position.
Replace the mirror, connect the wire harness (if heated or power) reinsert the molding, put the door trim on and bolt it back up. From start to finish taking your time, an hour or less.
Good luck!
Afe, 180 T-Stat, Predator, Proxes 4's ... Best time 12.91 @ 112.57
MCORegal is offline
EXPIRED: F/S: drivers side rear view mirror 2005_300c Parts Buy/Sell Forum 0 10-22-2008 07:28 AM
Side view mirror dipping issue with reverse. 4life General Discussion on Issues / Trouble Shooting 1 07-04-2008 07:24 AM
Driver side rear view mirror 2005_300c General Discussion 4 05-15-2008 09:24 AM
Side view mirror cover swap? Cthomas888 Appearance General Discussion 2 02-11-2008 10:06 PM
Side view mirror...haven't seen this yet Julius 1st Gen SRT8-Specific General Discussion 3 07-20-2006 10:52 AM
Replace with
