Transmission Problem 300C - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 08-23-2010, 11:47 AM   #11 (permalink)
Points: 245, Level: 1 Points: 245, Level: 1 Points: 245, Level: 1
Member Number: 28209
Originally Posted by Erik View Post
A little more info is needed than this.
Does it move at all? If you put it in gear, does the car start to move, but then won't change gears? Will the lever not go into gear? Does it make any odd noises?
Lots of great, knowledgable people on the site who are more than happy to help, but they need to know what it is doing exactly before they can help.
The car will move once I put it in Drive. It will not shift from first gear. No odd noises. I tried shifting into manual shifting but it won't go there.
FSOG13 is offline
Old 08-23-2010, 01:07 PM   #12 (permalink)
Points: 4,683, Level: 1 Points: 4,683, Level: 1 Points: 4,683, Level: 1
Grathe's Avatar
Member Number: 26460
TCM messed up???
Grathe is offline
Old 08-23-2010, 05:28 PM   #13 (permalink)
Points: 1,623, Level: 1 Points: 1,623, Level: 1 Points: 1,623, Level: 1
SanDiegoMob's Avatar
Member Number: 25708
Transmission solenoid and govener sensor gaurantee it no codes will pop up and no matter if you shift it manually youll stay stuck in first it happend to me.
2006 Chrysler 300c
Cool Vanilla
Ground Effects Body Kit
Bentley grill
F5 22's
Tint all the way around
SanDiegoMob is offline
Old 08-25-2010, 04:09 PM   #14 (permalink)
Got a call just now from the Dealer. Diagnosis: Connector inside tranny is shorted out. Cost $760.00. If it also shorted out the Transmission Control Module then it's $1160.00. I think it's time to dump this car.
Any comments about this diagnosis will be apreciated.
FSOG13 is offline
Old 08-25-2010, 07:03 PM   #15 (permalink)
Points: 311, Level: 1 Points: 311, Level: 1 Points: 311, Level: 1
Car: 2005 chrysler 300c AWD
Member Number: 28089
Holy crap that's high I would call a local transmission shop and get a quote from them on the price. Heck it can't hurt.
J300cAWD is offline
Old 08-26-2010, 01:04 AM   #16 (permalink)
Points: 1,722, Level: 1 Points: 1,722, Level: 1 Points: 1,722, Level: 1
Member Number: 10688
Besides this expensive tranny fix has the car been reliable overall?
If it has and the mileage isn't that high then it might be worth to fix.
300thebomb is offline
Old 08-28-2010, 11:41 AM   #17 (permalink)
So the saga continues on the tranny. Dealership called me this morning. There is water inside the transmission. That is what caused the connector to short and maybe also the control module. Besides this two problems the transmission should be replaced with a rebuilt one. Cost $4000. They don't know how the water got inside the tranny. Last work done on the transmission was back in March when they flushed the transmission. They say there is no connection between what they did and water in the tranny. I asked about a TSB on water inside the transmission. They say it's not related to this model. Where can I get the specifics on this particular TSB.
FSOG13 is offline
Old 08-28-2010, 12:21 PM   #18 (permalink)
I'm pretty sure it involves all 2005 models. the tsb # is 21-003-06
J300cAWD is offline
Old 01-29-2013, 07:43 AM   #19 (permalink)
Points: 33, Level: 1 Points: 33, Level: 1 Points: 33, Level: 1
Car: 2006 Chrysler 300c
Member Number: 42925
I have a 2006 chrysler 300c and my car does not go over 60 mph and stuck at 4000-5000 rpm can it be my transmission solenoid the code on the computer comes up as p0743 torque converter clutch circuit electrical. This all started when I went in a big puddle of water. Does anyone know where this solenoid is any pics advice would be great thanks a lot.
Enzomalik is offline
Old 01-29-2013, 07:45 AM   #20 (permalink)
300c
Does anyone know where the solenoid on transmission is code p0743 many thanks.
Transmission problem.... ILMAO Australia Forum 5 08-28-2010 04:16 AM
Transmission problem!!!! Kutman Performance General Discussion 27 04-24-2009 09:12 AM
Transmission Problem gigaDJ SRT8-Specific General Discussion 3 02-17-2008 09:27 PM
300C transmission problem flt505 Problems / Dealer Service 18 01-28-2008 10:53 PM
Is this a Transmission problem? patrickkoh General Discussion 9 09-14-2007 09:22 PM
