Tire pressure - Chrysler 300C Forum: 300C & SRT8 Forums
 1Likes
post #1 of 23 (permalink) Old 11-28-2010, 11:50 PM Thread Starter
Points: 6,079, Level: 1 Points: 6,079, Level: 1 Points: 6,079, Level: 1
Tire pressure
Hi,
I brought my 300C to the dealer for periodic maintenance last week. After getting back home and checking in details the bill, found the dealer set the tire pressure to 36psi (the manual says 30psi).
I don't think the dealer (a long time Chrysler dealer in California) tech was stupid of not to follow whatever it should be, especially it's now written black & white on the bill. Is it a general practice for dealers to set tire pressure 20% above manufacturer recommendation, or they just want the tire to wear faster for potential tires business?
Should the dealer have told their customers BEFORE doing it, or at least inform customer by the time of releasing the vehicle?
Any comments are appreciated.
Thanks.
WWTW
wwtw is offline
post #2 of 23 (permalink) Old 11-29-2010, 10:54 AM
Points: 3,314, Level: 1 Points: 3,314, Level: 1 Points: 3,314, Level: 1
jamesdtuttle's Avatar
Never trust a dealer or service facility to set your tire pressure correctly.
My SRT8 is supposed to be 32 psi all around. I've had two different Chrysler dealers overpressure the tires, and my local independent garage did the same thing (once). 45 psi makes her ride kinda hard.
The garage's excuse was that a pressure gage was defective. The second dealer told me he'd notified his employees and emphasized the need for correct pressures. The first dealer never got a return visit.
My recommendation ? Buy a tire gage and use it.
Jim
K&N CAI, modified Predator 93 Octane/CAI tune, DashHawk, Jet 180 thermostat, BT Catch Can, Toyo Proxes 4 245/45/20s front, Toyo Proxes 4 275/40/20s rear.
jamesdtuttle is offline
post #3 of 23 (permalink) Old 11-29-2010, 11:23 AM
Points: 37,638, Level: 1 Points: 37,638, Level: 1 Points: 37,638, Level: 1
The tyre pressure sticker on my car recommends 36psi front and rear, however I'm in Europe.
ivanford is offline
post #4 of 23 (permalink) Old 11-29-2010, 12:08 PM
Points: 88,359, Level: 1 Points: 88,359, Level: 1 Points: 88,359, Level: 1
GoofyTimL's Avatar
Car: '15 300C Platinum Jazz Blue; '07 MSRT8 Bright Silver MSRT: Edelbrock SC w/ InTune, 402flaps, Stealth HIDs, misc BT stuff, dual pin stripes, 35% tint 300C Pt: 35% tint, SpLx Pedal Set so far
Despite what the Mfg reccommendation is (30-32 psi) I have run my tires at 36 psi since day one because they wear more evenly (which means the Mfg rec. is too low IMHO) and it doesn't hurt fuel economy either.
but now there's the 300C Platinum and an Edelbrock SC Magnum SRT8!
GoofyTimL is offline
post #5 of 23 (permalink) Old 11-29-2010, 03:39 PM
Points: 887, Level: 1 Points: 887, Level: 1 Points: 887, Level: 1
I go with 34 & the dealer I got the tires from recommended 35-36..
skisby is offline
post #6 of 23 (permalink) Old 11-29-2010, 04:26 PM
Points: 94,380, Level: 1 Points: 94,380, Level: 1 Points: 94,380, Level: 1
Tetris Champion
HPNO300's Avatar
Car: 2006 Chrysler 300 Touring and SRT8
Send a message via Yahoo to HPNO300
i have mine set around 36 psi but i have 22s....i try not to let mine get below 34 psi and not above 38 psi and i recently had to add some air to my tires since they were below 34 psi and the mileage was horrible and since then has improved just a bit.
HPNO300 is offline
post #7 of 23 (permalink) Old 11-29-2010, 04:52 PM
ADMIMISTRATOR
Points: 299,130, Level: 1 Points: 299,130, Level: 1 Points: 299,130, Level: 1
Northern Rider's Avatar
On these cars, low tire pressures will wear out your tires faster than Madonna sheds knickers. . . .
I keep mine between 34 to 36 psi for street driving. I like them up around 40 psi for lapping on road circuits.
Patrick ... Latest List of Road Racing Mods ..........
2015 Charger Hellcat is in the stable!
Northern Rider is offline
post #8 of 23 (permalink) Old 11-29-2010, 06:56 PM
Points: 2,433, Level: 1 Points: 2,433, Level: 1 Points: 2,433, Level: 1
Scumbag Inc.™'s Avatar
Read the psi recommendation on your TIRE! Not the manual, not what it says in the door well.
Scumbag Inc.™ is offline
post #9 of 23 (permalink) Old 11-29-2010, 07:21 PM
Major Contributing Member
Points: 3,673, Level: 1 Points: 3,673, Level: 1 Points: 3,673, Level: 1
MikeHTally's Avatar
Wrong! The tire has no recommendations beyond the maximum bead-seating pressure and max load at max pressure. The door placard is the authority. I use 30 psi unless it's trip time. Then they go to 33 psi.
MikeHTally is offline
post #10 of 23 (permalink) Old 11-29-2010, 08:44 PM
Points: 24,569, Level: 1 Points: 24,569, Level: 1 Points: 24,569, Level: 1
dhoolwerf's Avatar
The recommended tire pressure is 32 psi COLD. If you checked your tire pressures as soon as you got home (hot), then 36 psi is probably about right. Check the tire pressure first thing in the morning after the car has been parked.
DO NOT fill your tires to the pressure stamped on the tire...this is the MAXIMUM tire pressure that the tire can safely be run at. The pressure noted on the drivers door jamb is the recommended pressure for maximum safety, economy and comfort.
dhoolwerf is offline
Tire Pressure for stock tire s0lidllama Custom Wheels & Tires 4 03-23-2009 11:06 PM
tire pressure mrbill General Discussion 9 12-13-2008 01:18 PM
EXPIRED: For Sale: 1 OEM SRT8 wheel with tire pressure sensor and almost new tire. SSpray Parts Buy/Sell Forum 9 11-09-2008 08:12 AM
tire Pressure! lpardo13 1st Gen SRT8-Specific General Discussion 2 07-06-2006 07:29 PM
Tire Pressure steven1m Custom Wheels & Tires 9 04-20-2006 07:13 AM
Replace with
