07-20-2007, 12:19 AM
#1 (permalink)
Car: 2007 Chrysler 300C SRT8
Member Number: 12895
Chrysler 300c Crd Performance
Hiflo has a performance upgrade module for the Chrysler 300C CRD that produces gains of up to 25% in power and torque.
The modules are developed in Europe by Tuning Box, one of the leading manufacturers of performance modules for diesel vehicles and we are their
Australian distributor. Visit their site on :WWW.TUNINGBOX.COM
The standard power figure of 160 kw goes up to approximately 198kw, and torque increases from 510 Nm up to 580 Nm!
This is achieved by modifying only the fuel injection parameters & timing. The turbo boost pressure is not influenced.
Our performance module reads information from the ECU, such as RPM, speed, throttle position, and adjusts the fueling parameters accordingly, to give you optimum power, economy and drivability.
On the road, the increased power and torque can be felt right through the engines rev range.The engines response is smooth and immediate, with no misfire or sudden unexpected surges of power.
Fuel consumption remains virtually the same in most driving conditions, and in some cases fuel economy can even be improved.
With its original equipment plugs, the module is quick and easy to connect, requires no cutting or modifying of the existing wiring loom, thus avoiding irreversible alterations.
And it is just as quick to remove, without leaving any trace of it having been fitted. [Especially prior to dealer servicing]
For 300C forum members, we are offering a special price of $799.00. This is a special saving over our normal list price of $880.00
A picture of the unit is at the bottom of this post.
OTHER ITEMS
We also carry a range of VDO gauges to help you monitor the performance of your 300C-CRD, such as turbo boost gauges and exhaust gas temperature [EGT] gauges, and a full range of fittings, line kits and other accessories.
An EGT gauge is highly recommended for diesel engines as it is the single most important indicator of how a diesel engine is performing.
[EGT – exhaust gas temperature also know as pyrometer]
Unlike a petrol engine, a diesel engine will continue to make power as more fuel is added. As more fuel is added, more heat will be generated until the motor just gets too hot and things start to melt and naturally this is a situation to avoid. Exhaust gas temperature is the ideal measurement of how hot the motor is, since temperature fluctuations in the gas are almost instantaneous.
You should seriously consider using an EGT gauge even if you make no performance upgrades, since EGT is such an important indicator of engine load, and is especially important when the engine is working hard, such as when you are towing.
An EGT gauge kit, including thermocouple, wiring loom & fittings at special forum pricing is $258.97
A turbo boost gauge, 0-30 psi, including line kit for fitting is $71.64 also at special pricing.
Pictures of the two gauges are available at the bottom of this post.
Mounting brackets and pods are also available.
**Note prices do not include postage.
If you have any additional questions, or you would like to place an order, you can email us at hiflo@hiflo.com.au,
call us on 03/9547 9222,
or outside of Melbourne toll free on 1800 817 006.
Also available is the revolutionary Dashhawk engine monitor. We will be posting more details about this amazing product next week.
Cheers
Steve
