Go Back   Chrysler 300C & SRT8 Forum > Supporting Vendors > High Horse Performance
Old 12-03-2006, 10:03 PM   #1 (permalink)
RandomAccess
HHP Group Buy Coordinator
RandomAccess's Avatar
Car: 2005 RT AWD Dodge Magnum
Member Number: 4214
HHP High flow Cats - AWD Installed!!!
Us 4 wheelers have been waiting for this for some time now... I begged Josh to make em... and they are HERE!
HHP and Josh are great... They knew that we were waiting so long for these, and a few of us had ordered several months ago, so as soon as they were manufactured he had JBA overnight them directly to us!
California to NY must have cost a fortune over night!! Thanks Josh.
I got them Yesterday, and spent the morning installing. It is a really easy install.
Installation
Jack up the front of the car, put em up on Jack stands. (If you are a large guy do the rear too... But I can slide under the car without doing that)
Unplug the two O2 sensors.
Unbolt the connections to the exhaust manifold on each side. (4 nuts on a stud if you have the stock manifolds. May have to struggle with nut an bolt if you have shorties) The stock setup is a nut, heat shield and another nut. I found using a 5/8" deep socket a swivel and a 6 inch extension reached all bolts well.
Loosen two band clamps that hold the mid pipes to the cat back. (The 5/8 worked for this too, but you may have different clamps depending on your exhaust)
Unbolt the cross member (13MM). You won't be able to free the cats unless you do this.
Now wiggle till their free... CAREFUL NOT TO DROP EM ON YOUR O2 sensor! WD40 may help.
Using a 1" open end remove the two O2 sensors.
Install the O2's in the new pipes.
Bolt up both pipes to the manifold... leave them very loose so they can be adjusted.
At this point I pulled off the two exhaust hangers in front of the pumpkin to make it easier to manuver the pipes in place.
Clean any carbon buildup in the pipe, gonna make working the new pipes in easier. I used some emery cloth.
Insert the mid pipe into your cat back. Wiggle till they are seated in there.
Now... Use a Jack to push the pipes up in place. I jack just in front of the cross member. If you don't do this... you'll be hearing your exhaust bounce on the cross member... VERY ANNOYING!
Tighten the nuts on the manifold, replace the heat shield and nuts.
adjust your exhaust to where you like it, make sure there is enough speace around all pipes. Use a pry bar if necessary to make fine adjustments. Tighten your band clamps.
replace the cross member. Replace exhaust hangers.
Check for leaks and road test.
Driving impressions:
On my magnaflow exhaust, I immediately noticed more of a growl when she started up. But it isn't louder or anything.
You DEFNINITELY notice a difference. I took her out for a spin and I can feel her to be much more responsive.
So I shut down esp and make a left. I floor it around the corner. She actually broke free for a second. I was half expecting a fishtail like a RWD, but instead she just slid to the right for a split second, caught and took off.
I can't wait to get her to the track to see what she'll do!!!
HHP has plenty of these in stock for both RWD and AWD. Josh has given me a discount code that I can share with anyone interested. PM me!
Michael
CLICK HERE AND DONATE! ITS FOR THE KIDS:
More than $4,000 in PRIZES!!!
FREE Stuff for all donations $50+
T-Shirts & Moddin'Art DVD's!!!
2005 Magnum RT AWD, Inferno Red
AIR Hammer, Jet POWR-FLO TBI Spacer
HHP High Flow Cats, Magnaflow
Predator, Taylor shorty wires
Stant 180* TStat, ESP Mod, RP XPR
ZEX 100 Shot
AVIC-D1, Reverse Cam
Cel Phone Mount, leather Console cover, Katzkin Leather interior
13.461 @ 104.18
RandomAccess is offline
Old 12-04-2006, 07:17 AM   #2 (permalink)
DUBSTER
DUBSTER's Avatar
Car: 2005 CHRYSLER 300
Member Number: 4939
Seweeeeeeeet!!!
DUBSTER is offline
Old 12-04-2006, 08:54 PM   #3 (permalink)
MPCLBJ
Car: 2006 Chrysler 300C AWD
Member Number: 9839
Thanks for the installation lesson. Considering a Borla stainless cat-back system. Your information makes the decision easier.
MPCLBJ 2006 300C AWD 14.171 @ 98.87 (Pure Stock - so far)
MPCLBJ is offline
Old 12-04-2006, 08:56 PM   #4 (permalink)
CplDaugherty
CplDaugherty's Avatar
Member Number: 5668
Wow, great job! Excellent write-up I'm sure alot of AWD owners will appriciate it.
CplDaugherty is offline
Old 12-05-2006, 11:34 AM   #5 (permalink)
Big Bob
Big Bob's Avatar
Car: 2005 AWD 300C
Member Number: 2907
Thank's HHP, I ordered mine today!
Silver 300 C AWD
All options......
signature pics by Lik2race......
Big Bob is offline
Old 12-05-2006, 12:34 PM   #6 (permalink)
Electrofied
Electrofied's Avatar
Car: 2005 Dodge Magnum RT
Member Number: 5554
Thank you Big...
E
Electrofied is offline
Old 12-05-2006, 06:13 PM   #7 (permalink)
RandomAccess
Member Number: 4214
You still can't beat me!! LOL
Old 12-05-2006, 06:14 PM   #8 (permalink)
RandomAccess
Member Number: 4214
Overnighted from JBA... Car up on Jack Stands
A few shots after the install, plenty of clearance all around. Good fit!
Old 12-10-2006, 03:40 PM   #9 (permalink)
Big Bob
Big Bob's Avatar
Car: 2005 AWD 300C
Member Number: 2907
Is that a juice bottle that I see on your car, ,...... You wait until spring when I pull out all the stops just to beat you. one of my new secret mods is to shoot out your tires.
Big Bob is offline
Old 12-10-2006, 03:42 PM   #10 (permalink)
DUBSTER
DUBSTER's Avatar
Member Number: 4939
Very clean install!!
DUBSTER is offline
