Old 03-27-2008, 10:07 AM   #1 (permalink)
Car: 2006 Chrysler 300
Member Number: 17217
Sueding Headliner Issues
I am in the process of sueding the headliner, but I am running into a few problems.
1. I got the headliner dropped and I did remove it from the car, through the rear driver door. I had to bend it pretty severely and only did it that way because I am gonna suede it and cover up all the wrinkles. So what is the proper way of taking the headliner out of the car? I will need to know for a smoother reinstallation.
2. The rubber trim around the sunroof, is Tan of course I want to make it black. Anyone successfully dye it or otherwise?
3.Sunroof cover, with the headliner out. I also need to suede the sunroof cover. How do I remove it from the car? It seems to be all one peice, bolted into the roof of the car and riveted together glass, tracks, and cover. I can remove the whole assembly motors and all but ti doesnt really give any insight onto the removal of just the cover peice.
PS- Nvm #3, I lowered the rear of the sunroof assembly, scrapped off the green foam squares glued to the roof of the car and slid the cover out the rear of the tracks.
Dman007 is offline
Old 03-27-2008, 01:27 PM   #2 (permalink)
Member Number: 707
They must pull the windshield. Don't you think?
Combat Hemi is offline
Old 03-27-2008, 02:28 PM   #3 (permalink)
Flossin22s's Avatar
Car: 2006 chrysler 300
Member Number: 2931
i put my headliner back asap so the glue was kind of fresh so i could adjust it when it was in there and didnt have to worry about wrinkles after.........i did the same and folded it
Flossin22s is online now
Old 03-28-2008, 08:32 AM   #4 (permalink)
Which door did you remove it from? The front doors have the widest openings, but I was unable to manuever the cover in a way to remove it from the front. I dropped the headliner, pushed it all the way back to the rear window, then moved it forward tot he right of the steering wheel, so that the front right corner was out the front pass door and the the left rear corner was out the driver rear door, then I almost had to fold it in half to get it out the rear driver door. There is probably an easier and less distructive way, I just gotta find it.
Dman007 is offline
Old 03-28-2008, 12:41 PM   #5 (permalink)
INeedMorePower's Avatar
Car: 2007 Chrysler 300C SRTDG
Member Number: 10564
I've read that taking out the back window is the other option.
Club: Triangle Mopars (North Carolina)
Mods: Aluminum Pedals, 4" Exhaust Tips, Roof Wing, Custom Engine Shroud, BT caps, Under hood fender covers, BT stereo knobs, Black Dash Kit, iPod integration
Future Mods: Custom Grille (under construction), Lowering, Vented Fenders, Cam, CAI, Predator
INeedMorePower is offline
Old 03-28-2008, 03:12 PM   #6 (permalink)
Flossin22s's Avatar
Member Number: 2931
rear driver side........i removed the rear bottom cushion so the front seats could go down further and removed the headrests as well
Old 03-29-2008, 09:59 AM   #7 (permalink)
So in my attempts to put the headliner back in, I has to fold the crap out of it almost in half. But its truely the only way possible. I myself went from the pass front door. But by folding it in half, you can get it in from any door I assume. I creased the cardboard backing and even tore it in some spots. But there is not other way. Good thing I sueded it, to cover up all the wrinkles. Chrysler must have installed it in first before putting the windows on. Poor design if you ask me.
Dman007 is offline
Old 03-29-2008, 10:44 AM   #8 (permalink)
jaded300c's Avatar
Car: Satin Jade Pearl 2005 Chrysler 300C ASHA Edition
Member Number: 15585
suede headliners are so 2004.
jaded300c is offline
