Old 05-12-2008, 01:27 PM   #1 (permalink)
kenk
kenk's Avatar
Car: 2006 Chrysler 300C Silver Steel Metallic
Member Number: 11516
Steering Wheel Insert Removal
A Chrysler tech dug through some manuals and gave me the following directions to remove the four silver plates on the spokes of the 300C steering wheel so I could send them to Kingpin at patterntek to have them coated.
1. Most important step: Disconnect the battery and wait a minimum of 2 minutes before proceeding to make sure that there is no latent electrical charge in the car. Two minutes is a minimum!
2. Using a 10mm socket wrench, remove the two bolts on the backside of the steering wheel. There is one on each side of the column behind the two top spokes.
3. Gently pull the entire center section of the steering wheel towards you and remove it. This is where you want to make sure the power is disconnected. The tech said that a stray electrical shock could be enough to set off the air bag inside the center section of the steering wheel.
4. The screws, etc that hold the metal inserts should be visable.
5. Reverse the proceedure, just as carefully, to put the car back together for use while the inserts are off being coated.
6. He said that the only thing he knew of that might have to be reprogramed is the "auto-up" window feature if you have it.
kenk is offline
Old 05-13-2008, 12:02 PM   #2 (permalink)
Manny 08
Car: 2007 Chrysler 300C
Member Number: 17599
People love pictures
Interior painting process has begun - Dodge Charger Forums
Can this feature be programmed for the back windows
Manny -
Manny 08 is offline
