Old 05-31-2008, 10:37 AM   #11 (permalink)
BCasey's Avatar
Car: 2007 Chrysler 300 Limited
Member Number: 17593
is there any way to get it off without a panel removal tool?
BCasey is offline
Old 05-31-2008, 03:11 PM   #12 (permalink)
Car: 2008 Jeep Grand Cherokee SRT8
Member Number: 14202
You could try to use a screwdriver to pop the clips, but you may scar the dash.
Mike_Levy is offline
Old 06-02-2008, 11:52 AM   #13 (permalink)
BCasey's Avatar
hmm I got it out, now my issue is that i dunno whats wrong with it. is it possible that with ALOT of use the grease is no good on the parts? The spring is there and looks ok, no wires in it, its just very stiff to open.
I know the guy who owned that car before me smoked in it and myb it just needs some lube?
BCasey is offline
Old 06-02-2008, 12:00 PM   #14 (permalink)
Casey's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 11732
did you use a panel remover? or just the screw driver? i dont want to damage anything, but unless autozone has a panel remover, im going to have to use a screw driver.
Casey is online now
Old 06-02-2008, 01:02 PM   #15 (permalink)
BCasey's Avatar
i just opened the ash tray, put my fingers on the bottom part of the panel and pulled it. its held in by clips that come out.
It took me a while cause i though id break it so i kept stopping and rethinking i but eventually i gently but firmly pulled it hard enough and the bottom clips came off and then the rest was a breeze
BCasey is offline
Old 06-02-2008, 01:54 PM   #16 (permalink)
Casey's Avatar
oh okay, open the ash tray and then put your fingers in the opening above the ash tray and just pull hard? i can try that.
Casey is online now
Old 06-03-2008, 07:05 AM   #17 (permalink)
Careful doing it that way if you have Navi. The bezel sides around the screen are kinda weak. I've snapped a bezel in half trying to just pull it off.
