Like many systems in our Chrysler 300Cs, the heated seats are controlled by a module. The module for the heated seats is mounted under the front passenger seat. It is wired to, along with other things (like headlights, parking lights, and turnsignals), the Front Control Module (FCM).
Sounds to me, if you had to do any wiring of the HIDs other than unplugging existing connectors and plugging in connectors from the HIDs, that you got some wires crossed.
If so, I suggest that the installation of the wiring be double checked, and/or re-establish the original wiring to see if the heated seats return to normal operation. Then straighten out the wiring problem.
