Old 02-09-2006, 05:55 PM   #1 (permalink)
NOLMTZ99's Avatar
Car: 2005 Touring 300
Member Number: 3782
Send a message via AIM to NOLMTZ99
overhead LED lights
How do i go about changing the overhead lights in my car, does the entire unit come down or do the lens' pop off. any info is appreciated. Thanks
Frank
NOLMTZ99 is offline
Old 02-09-2006, 07:07 PM   #2 (permalink)
VIP EDITIOn's Avatar
Car: 2005 chrylser 300c
Member Number: 4793
Frank
hey very easy, get a negative screw driver, or anyhin long nad flat. start from putting it to the left or right of the lens dont matter which one, and snap it down, if you need to go and do opposite side, if it dont work first time, dont worry i was the same, just DO IT!!!!
VIP EDITIOn is offline
Old 02-13-2006, 11:52 AM   #3 (permalink)
Car: 2004 Durango Dodge
Member Number: 4725
where does one get the LED bulbs in question.
Richard Sudol
2004 Dodge Durango SLT
Mods
Splash Guards
Hood Bug Shield
New Pewter Billiet Knobs for all controls
K&N Drop in Air Filter
Mounted Ipod in custom bracket
Rec Navigation Unit
Factory Remote Start
Factory Uconnect
Chrome Exhaust Tip
rsudol is offline
Old 02-13-2006, 12:43 PM   #4 (permalink)
FreebirdSRT's Avatar
Member Number: 4247
Trader Rating: (10)
You can get them from www.superlumination.com Chris is the owner of the site and was very helpful in helping ensure I got the right sizes for all the led upgrade locations, on the 300. This is the list from my order (I ordered all LED's in super bright white color, they are also available in colors and black light). I did not upgrade to the LED turn signals, you will need to buy 4 load equalizers as well for the turn signal LED upgrade.
2006 Chrysler 300C SRT-8
INTERIOR:
1. Dome/Map lights (roof) : #578 = Festoon 9 LED rigid loop. (Size: 44 mm = 1.75") $ 7.99 ea. (2)
2. Step/Courtesy lights (bottom of both front doors): #562 = Festoon 9 LED bulb rigid loop. (Size: 44 mm = 1.75") $ 7.99 ea. (2)
3. Rear Dome/map lights: #194 = 194 5 LED matrix bulb. $ 6.99 ea. (2)
4. Glove box light: #194 = 194 5 LED matrix bulb. $ 6.99 ea. (1)
5. Trunk/ Cargo light: #921 = 921 9 LED Matrix bulb. $ 6.99 ea. (1)
EXTERIOR:
1. Brake Lights #3057 = # 3157 Light Tower (20 wide angle) Brake Light LED's in Red color. $ 19.99 ea.(2) No equalizers required for the Brake Light LED's.
Hope this helps you out in at least getting started. PM me if you have any other questions about the LED upgrade mod.
Eleanor Roosevelt, 1936
FreebirdSRT is offline
Old 02-13-2006, 06:37 PM   #5 (permalink)
Member Number: 1156
INTERIOR:
EXTERIOR:
1. Brake Lights #3057 = # 3157 Light Tower (20 wide angle) Brake Light LED's in super bright white. $ 19.99 ea.(2) No equalizers required for the Brake Light LED's.
One quick fix, the LED for the overhead maplights isn't the rigit loop festoon, its just the normal 44mm Festoon!
dipster is offline
Old 02-13-2006, 07:20 PM   #6 (permalink)
TheDon300's Avatar
Member Number: 1042
Send a message via AIM to TheDon300
have any of you changed the bulbs for the license plate? I know that the new IS 250/350 have led bulbs for the license plate
TheDon300 is offline
Old 02-13-2006, 08:09 PM   #7 (permalink)
Member Number: 4247
Trader Rating: (10)
I sent Chris pictures of all of my bulbs, from my SRT. My OEM overhead dome/map light bulb had loops on the end. Albeit, not very large ones, Chris told me to go with the festoon loops. Some members were mentioning a 39mm but Chris said that even though my OEM dome light measured just under 1.75" it was better to go to the 44mm than the 39 mm and it be snug and not move around with bounces, etc. Chris also said when measuring, make sure it is from loop to loop, not end cap to end cap of the OEM's.
Old 02-14-2006, 12:04 AM   #8 (permalink)
Member Number: 1156
Wow, interesting!
My 05C didnt have loops, perhaps they changed for the 06 or SRT?
thanks for the info!
dipster is offline
Old 02-14-2006, 03:28 PM   #9 (permalink)
Buz-CCC's Avatar
Car: 2008 Chrysler 300C
Member Number: 3268
No loops on my 2006 maybe on SRT
Ed,
2008 Silver l 300C/Dk Slate Int.Everything except rear VES! Del 8/26/08
Mods Slate Slush Mats/Mopar Molded Splash Guards
SS Pillar Trim/SS Trunk Lid Trim
Led's all Int. Ext. Flasher Stop 20 led towers in tail Backup 50 watts (Bright)
24oz Slate Mats (Hemi) DRL's Enabled
Buz-CCC is offline
Old 02-14-2006, 03:35 PM   #10 (permalink)
Car: 2006 Chrysler 300C SRT-8 Hemi
Member Number: 4841
Send a message via AIM to gable
anyone able to post some pics of what these look like
guess i'm wondering why you'd go through changing all these out when its just light that isn't really on much unless i'm missing something
thanks
matt
2006 300C SRT-8
Silver Steel
All options but rear dvd
Born 11/15/05
Became mine 1/28/06
My life has forever changed
prior: 1977 Trans Am
gable is offline
