Canbus Question? - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Appearance Forums > Lighting Discussion
Lighting Discussion This area is for discussion of all things related to lighting. Such as: HIDs, Turn Signal Bulbs, LED tails, Interior Xenon bulbs, etc. for the Chrysler 300 or other LX models.
Old 11-06-2012, 02:56 PM   #1 (permalink)
Points: 7,220, Level: 1 Points: 7,220, Level: 1 Points: 7,220, Level: 1
Car: 2011 Chrysler 300C HEMI
Member Number: 36494
Canbus Question?
I recently placed an order for a H11 HID kit (Morimoto) from TRS and am having second thoughts about if I should of ordered the kit with the Heavy Duty relays instead of the Canbus relays. My question is which wiring kit should I have ordered?
I contacted TRS and they reccomened just the Heavy Duty harness for the H11 fogs in my 2011 300C.
What are your guys thoughts on this?
Patdow1 is offline
Old 11-06-2012, 08:59 PM   #2 (permalink)
Points: 28,869, Level: 1 Points: 28,869, Level: 1 Points: 28,869, Level: 1
MADDOG's Avatar
Member Number: 11602
You don't need the relay harness for the foglights. Just for the headlights if you are converting to HID lowbeams from a stock halogen setup.
Yer good to go.
Michael
MADDOG is offline
Old 11-06-2012, 10:47 PM   #3 (permalink)
So if im understanding you correctly, all I need is the supplied Heavy Duty wiring harness for my fogs.
Patdow1 is offline
Old 11-07-2012, 09:37 AM   #4 (permalink)
MADDOG's Avatar
All you need is to wire in the ballasts to the stock harness so if they are offering a harness without provisions to interface with the CanBus system, then that's the one you need.
I have no relays whatsoever in my foglight harnesses and they work flawlessly. I'd ask them why you need relays in yours.
MADDOG is offline
Old 11-10-2012, 11:51 PM   #5 (permalink)
I ended up getting the kit without the Canbus relays after explaining to TRS that these were for my fogs and not my headlights. I'll post pics of the install and all supplied parts and end results.
Patdow1 is offline
Old 11-11-2012, 02:30 PM   #6 (permalink)
MADDOG's Avatar
Sweet. Post 'em up!
MADDOG is offline
Old 11-20-2012, 10:33 AM   #7 (permalink)
I ended up not liking the 3000K as much as I though I would so I ended up returning them for other reasons and opted for the 4300K this time around. I definately will post pics when they get here some time next week
The only complaint I have with the wiring of the kit to the fogs is that the kit comes pre-wired to go into headlamps because they include a rubber grommit and spade connectors that plug into the factory harness. I will end up modifying the new kit to be a cleaner install next time around with factory style connectors.
Patdow1 is offline
Old 12-22-2012, 11:49 PM   #8 (permalink)
Wired up my HID kit to my factory harness and the drivers side flickers. I swapped everythgin over and it is not faulty wiring or ballast. Any idea what the problem could be?
Patdow1 is offline
Speed limit via CANBUS - any CANBUS experts on the forum? Chill General Discussion 2 11-27-2007 08:29 AM
CANBUS hacking? 345CID Car Audio/Alarms/UConnect/Navigation 7 06-26-2007 05:37 PM
canbus on 4 speaker??? and alarms? jayfus Car Audio/Alarms/UConnect/Navigation 3 01-23-2007 06:11 PM
Canbus interface Blowndakrt Car Audio/Alarms/UConnect/Navigation 14 01-23-2006 01:04 AM
