Halo Help ASAP - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Appearance Forums > Lighting Discussion
Lighting Discussion This area is for discussion of all things related to lighting. Such as: HIDs, Turn Signal Bulbs, LED tails, Interior Xenon bulbs, etc. for the Chrysler 300 or other LX models.
Old 01-15-2013, 08:14 AM   #11 (permalink)
gsp
Points: 1,034, Level: 1 Points: 1,034, Level: 1 Points: 1,034, Level: 1
Car: 2009 Chrysler 300 touring
Member Number: 27617
Thanks for all the help guys. I really appreciate all the help so far and hope to get it all figure out soon. I will keep you update.
gsp is offline
Old 01-15-2013, 04:14 PM   #12 (permalink)
Points: 13,714, Level: 1 Points: 13,714, Level: 1 Points: 13,714, Level: 1
silver06hemic's Avatar
Car: 2006 Chrysler 300c
Member Number: 18438
Originally Posted by Xstylezz View Post
IT SHOULD BE THE FUSE ....that same thing happen to me when i did the srt front end conversion on my touring 300.. the turn signals worked but wouldn't come on with the lights and my tails went out and only worked when i hit the brake (Check the *15* fuse in the front fuse box) and the (*25* fuse in the Rear fuse box) those might be the ones that are burnt out cause that's what i had to swap to get it corrected... hope this works out
It won't be a fuse... He has one operational headlight... the fuses mentioned can be an issue with problems like you had, however one fuse does both headlights, if one works then it really can't be a fuse. Still say check your ground... replacing your headlight will also fix it if the problem is an issue within the housing.
Johan Tune, FRI'd (Sidewinder & Street/Strip Heads), Ported SRT Headers & Gutted Mid's, EGR, MDS & rear 02 Delete, Custom Catback with Blastin Bobs SRT Pipes 4" tips, 170 Tstat, Ducted AH CAI, Big Bully Catchcan, 3.06 diff w/upgraded axles, 2800 stall 'verter, MTCM, Tranzformer, Brembo GT w/D&S & Hawk pads, 5/15% Tint, SRT 20's, SRT Spoiler & Bumpers, Custom Stainless Grill, 6k Fogs, Eibach drop..what's next?
0-60 - 10.8 secs with 650' of rubber! 371rwhp/392rwtq
silver06hemic is offline
Old 01-16-2013, 01:43 AM   #13 (permalink)
Points: 1,825, Level: 1 Points: 1,825, Level: 1 Points: 1,825, Level: 1
Member Number: 29598
when I said to wire the halo to the battery it's to test the halo if it's working OK or not, not to leave it connected all of the time
typan is offline
Old 01-17-2013, 09:41 AM   #14 (permalink)
gsp
well the stories go on. I got pulled over last night because I have no tail lights now. Not sure whats going on. Never thought that a simple plug and play headlight set could cause so many problems.
gsp is offline
Old 01-27-2013, 08:24 PM   #15 (permalink)
gsp
Got everything fixed. I just had to replace the inverter and the problem was solved. Easy enough. Thanks for all the help!!
gsp is offline
First look! New Flashtech RGB Halo and 14v Halo Release Information steve@flashtech Lighting Discussion 10 05-10-2012 12:34 PM
To Halo or Not to Halo!?! (Moved) CSand78 Lighting Discussion 20 08-04-2009 03:00 PM
WTB: halo inverters ASAP?? drewmin Parts Buy/Sell Forum 5 05-19-2009 07:07 PM
