Old 08-19-2007, 04:23 AM   #1 (permalink)
Michaelr
Michaelr's Avatar
Car: 2007 Chrysler 300c
Member Number: 10626
Condensation in aftermarket Tail lights
My wife has a set of aftermarket tail lights in her PT Cruiser and gets condensation in them. I was wondering if this is common problem in plastic tail lights. I would like to know how you get rid of it.
regards Michaelr
Regards Michaelr
Score B2 M1
Michaelr is online now
Old 08-19-2007, 04:42 AM   #2 (permalink)
rangrov
rangrov's Avatar
Car: 2006 chrysler lux pack 300c CRD tourer UK Estate Car
Member Number: 13071
Lightbulb How To Get Rid Of Condensation In Lamps.
I have just done one on my 300c, take the whole lamp out remove bulb holders, take it in the house place at the side of a dehumidifier,,,,, if you have one,,,, if not stand over a houshold radiator with it heated,,,, or get the wifes hair dryer and on a hot setting warm the lamp up inside and out till there is no condensation,,,,, check that there is no water lying in the bottom of the lamp, if so drill with an 1/8th drill 2 small holes into the bottom black plastic not the outside were you will see it. let it drain then warm it up till bone dry, then get some water proof silicone the type used for showers etc and run a bead round the entire lamp, hey presto no more condensation. IT WORKS FOR ME........ PS YOU DO NOT HAVE TO SILICONE THE BASE OF THE LAMP..........
LIVE LIFE TO THE FULL THIS IS NOT A REHERSAL.
PRIVATE PLATE
LUX PACK ( SAT NAV, SUN ROOF, SOUND )
STARTECH GRILL
CHIPPED
22" ALLOYS
DE BADGED
TINTS ALL ROUND
WINDOW WIND DEFLECTORS
VES IN REAR ( DVD )
STEALTH LIGHTS AND BULBS
UNDER FLOOR LIGHTS
LEATHER ARM REST
TALEX SYSTEM ( RADAR )
FACTORY MUD FLAPS ALL ROUND
WOODEN DASH ( EDASH )
SHEEPSKIN CARPETS MAYBE?
rangrov is offline
Old 08-19-2007, 04:51 AM   #3 (permalink)
Michaelr
Michaelr's Avatar
Thanks for the tip rangrov. I will definitely give that a go.
regards Michaelr
Old 08-19-2007, 08:01 AM   #4 (permalink)
wantit
Car: 2006 Chrysler 300 srt8-every available option
Member Number: 1578
thats the solution!
exactly what rangrov said. I have the sonar led tails, and had the condensation issue. don't be afraid to use the silicone, seal all seams and anywhere you think moisture can enter. use the clear stuff, and just be sure the insides are dry before reinstalling. you will have no more problems.
wantit is offline
Old 08-19-2007, 09:29 AM   #5 (permalink)
DYNAMITE44
DYNAMITE44's Avatar
Member Number: 9404
exactly what they said, but also keep in mind that with some cheap aftermarket tail lights, the sockets they use to retain the bulbs aren't the greatest. after a mud run with the jeep, i found that the bulb socket was the problem. it was easy to spot because there was mud inside the tail light around the bulb. the sockets might be something to check, but i'd advise against siliconing them into place. in the event that one of the bulbs burns out, you'll have a fun time trying to get it out. you might want to try a little bulb grease, avaliable at most auto parts stores.
DYNAMITE44 is offline
