Old 10-20-2007, 08:31 PM   #1 (permalink)
Car: 2005 chrysler 300 C AWD
Member Number: 9228
Exclamation 6000k Hid Kit With No Relays Incl... How To?
hey Everyone...this Is My First Post Here...i Have A 2005 300c Awd And Just Purchased 2 6000k Hid Kits From My Friends Shop,$200 A Set, One For The Low Beam And One For The Fogs, But They Do Not Include Relays. Have The Ones For The Low Beams Installed But They Flicker Like Crazy And Cannot Use Them. Can Somebody Give Me Some Detailed Insight On How To Integrate The Relays..pics If Possible....or A Better Solution To Return These And Buy New Ones....thanks!
Anthony
Boston Ma
anthonyri is offline
Old 10-22-2007, 08:12 AM   #2 (permalink)
DWINWARD's Avatar
Member Number: 13312
This is what you are going to need two relays, two 50ohm 10 watt resistors.
Put the resisor across the factory wires. Then connect terminals 85 and 86 on the relay to the two wires that you connected the resistor to. Then connect terminal 30 on the relay to a constant 12 volt positive. Connect terminal 87 on the relay to the positive input in your hid kit. Then ground the hid kit. Do this for both sides. Then you should no more flickering.
Here is what the resistors and the relays look like.
22 ELITE CONSOLE COVER
35% REAR TINT 50% FRONT
8000K HID FOGS/HEADLIGHTS
CLEAR FRONT CORNERS
COLD AIR INTAKE
CHROME GRILL
12'' JL SUB
ALPINE 200 WATT AMP
NO RESONATORS
NO ESP
DERRICK-
DWINWARD is offline
Old 10-22-2007, 11:53 AM   #3 (permalink)
Member Number: 9228
Thanks Bro...but Im Probably Just Going To Buy Those Stealth Auto Kits With The Smaller Ballasts And Capacitors Integrated, They Are Cheaper Too....$175/kit
