Old 07-10-2008, 08:47 PM   #11 (permalink)
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (18)
I did this 2 1/2 years ago.. only I didn't cut anything I used the stock wiring as the connections are already there.
the bottom lights in Europe are the rear fog lights..
I put LED strobing lights in my lowers so they wig-wag flash 3 times then go solid..... extra caution/alert
Life summed up by Mike Shinoda:
"10% Luck: 20% Skill: 15% Concentrated Power of Will: 5% Pleasure: 50% Pain"
Mr. iNCREDIBLE is offline
Old 07-24-2008, 12:13 PM   #12 (permalink)
prican_2000's Avatar
Member Number: 5521
Send a message via Yahoo to prican_2000
Mr. I can you please explain how it was that you did this mod without cutting anything?????
When the RICH wage war, it's the POOR who die.
Semper Fi
Brilliant Black 2006 300C
Current Mods:
-Air Hammer
-SuperChips FlashPaq <----FOR SALE!
-Custom Flowmaster (40s) Exhaust w/S.S 4in Blastin Bob Resonated SRT8 Tips
-FRI-Sidewinder Cam with Custom Push Rods
-MHP Ported Oil Pump
-Gibson Shorty Headers
-Tein Lowering Springs
-Custom Stereo System
-Custom Radar Mount w/Passport 8500 BLUE
-Custom Switchblade Key by Dgenowa (Coming Soon!)
At the Track:
13.8 on Air Hammer & Super Chips.
prican_2000 is offline
Old 07-24-2008, 01:13 PM   #13 (permalink)
Member Number: 5683
Trader Rating: (18)
there is a rubber water seal grommet on the bottom of the plug.. pull it out and run a wire thru it on the 3rd side that is empty, solder the wire to the clip that is on the inside of the connector..
run the wire to the top light and remove the rubber grommet there, solder the bottom light wire to the top light brake wire (run the wire through the hole where the brake wire is, tight fit but can be done)
reinsert the rubber grommet into the connector base.. that's it.. took about 10 minutes for each side..
Old 07-24-2008, 02:15 PM   #14 (permalink)
Member Number: 5521
SCHMOOOOOKIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks Mr.I !!!!!!!!!!!!!!!!
You come through yet once AGAIN.
