Old 02-07-2008, 05:48 PM   #1 (permalink)
DESIREE
Member Number: 1483
Quad Brake Lights For The 300c
QUAD BRAKE LIGHTS FOR THE 300C
Since their introduction I noticed that only the top/round portion of the 300C’s taillights were used for the brake lights while both the top/round and bottom/rectangular portions were used for parking lights. Then the other day I noticed that the bulb in the bottom/rectangular portion actually had the minor and major filaments as in the top/round portion. So I thought I’d take a look into what it would take to get brake light power to the major filament of the bottom/rectangular portion’s bulb, and in the process yield quad brake lights.
To see how I did it, read on.
After opening the trunk, I located and removed the plastic wingnuts (one each side) that retain the interior trunk paneling.
Then I pulled the paneling forward to expose the electrical connector, slid the locking key, pulled the plug, and removed the wingnuts (two each side) next to and above the socket.
I then removed the taillight assembly by pulling it straight back and off of the fender, and took it to
the workbench to modify the wiring.
I found that the green socket at the bottom inside of the taillight assembly needed to be modified to add a third wire to bring brake light power into the socket so as to energize the major filament.
First, I cut the Black/Gray and White/Violet wires coming out of the green socket about 2” from the socket (I’ll explain why this is necessary later). Second, I removed the socket from the taillight assembly, and removed the bulb for safekeeping. Third, I stripped the four ends created by cutting the two wires about 3/8”, and twisted the bare wire ends.
After careful inspection of the contacts within the socket, and those on the 3057 bulb, I determined that there is a metallic tab within the socket in a position to contact the bulb’s base at the major element’s contact location. This position in the socket is located 9/16” in from the side and 3/4" below the top of the socket’s rim, as labeled in the picture.
To gain access to this metallic tab I first carefully drilled a 3/32” pilot hole just through the plastic until the drill bit bumped into the metallic tab within. Then I upsized the hole to 1/4", all the while being careful not to allow the drill bit to be suddenly pulled into the socket and wiping out the metallic tab in the process! As required, I removed plastic from the edges of the hole to fill out its full diameter with an Exacto knife. I then applied a bit of solder flux to the metallic tab, followed by a dab of solder (as pictured). I applied just enough heat to get the solder to stick to the metallic tab and not melt the plastic that retains the metallic tab.
Next I prepared a 12” long piece of hookup wire to be soldered into the hole of the socket by striping 1/4” of one end, tinning it with solder, and bending the end in two reverse 90-degree bends (as pictured).
I then trimmed the end of the soldered area back to about 3/16” to allow the end of the wire to enter the hole in the back of the green socket. After positioning the end of the wire in the hole I carefully positioned the soldering gun tip to the joint and applied sufficient heat to melt the solder on the wire to the solder on the metallic tab.
The bulb was then re-installed in the socket and the socket/bulb assembly re-installed into the taillight assembly.
Now for the explanation as to why the Black/Gray and White/Violet wires were cut earlier in the instructions. While doing so eases the operations of drilling the hole and soldering in the third wire, this is not why they needed to be cut. I discovered the necessity for this while pre-testing the operation of the newly wired major filament of the green socket’s bulb, which didn’t work exactly right! After further study I determined that the internal connections of the green socket (which was intended for minor filament operation only) needed to be cut in order to flip their connections so as to reverse the ground and minor filament power sources within the socket. This moved the ground wire to the ground connection point of the major filament of the bulb, and all was well.
So, I spliced the Black/Gray and White/Violet wires in the flipped configuration as pictured to achieve the required results.
Next, I extended the third wire from the green socket up to the black socket of the brake/park bulb, and spliced it into the Dark Green/White wire. I soldered the connection (as picture below) and taped the joint.
Then I went back to the green socket and applied a dab of silicon adhesive/sealant to the hole to seal up the wire entrance into the socket as pictured below.
The finished product should look like this from the inside ………………….
……………….and like this from the outside when re-installed on the car:
For those who would like a .doc or .pdf version of this information drop me a PM with your e-mail address indicating which (.doc or .pdf), and I'll send it off to you.
DESIREE is offline
Old 02-07-2008, 08:38 PM   #2 (permalink)
Inferno07
Inferno07's Avatar
Car: 2007 Chrysler 300C
Member Number: 16364
Send a message via ICQ to Inferno07 Send a message via AIM to Inferno07 Send a message via Yahoo to Inferno07
Fantastic write up with great photos! THIS is what makes any forum great!
2007 Inferno Red 300C - Stock for now, but not for long!
Brett DiMichele
Inferno07 is online now
Old 05-06-2008, 12:14 PM   #3 (permalink)
prican_2000
prican_2000's Avatar
Member Number: 5521
Send a message via Yahoo to prican_2000
This is an AWESOME Write up _ TWO THUMBS UP!!!!!!!!!!!
But couldn't you just get another set of the upper black sockets and then ran the wires that way and saved yourself alot of hassle???
Home of the Free Because of the Brave.
SEMPER FI
WWW.PM-FL.COM
Brilliant Black 2006 300C
Current Mods:
Air Hammer
SuperChips FlashPaq
Custom Flowmaster (40s) Exhaust (No Suitcases or Reso's)
At the Track:
13.8 on Street Tires with Air Hammer & Super Chips.
prican_2000 is offline
Old 06-21-2008, 07:03 PM   #4 (permalink)
DESIREE
Member Number: 1483
Sorry about the delayed reply, but I just haven't checked the posting for awhile.
The answer to your question is NO!
Here's why: the keyways on the two sockets (green and black) are indexed differently, so the black socket will not plug into the hole where the green socket goes.
Somebody at Chrysler probably figured they'd keep people from putting things together wrong. Clever, or what?
DESIREE is offline
Old 06-21-2008, 07:36 PM   #5 (permalink)
bluepearlcee!
bluepearlcee!'s Avatar
Car: 2007 chrysler 300C
Member Number: 17075
... man, I like this mod! Just might have to try it someday...
bluepearl cee-ya!
bluepearlcee! is offline
Old 06-23-2008, 07:53 AM   #6 (permalink)
prican_2000
Member Number: 5521
Thumbs up
AWESOME!!!!!!!
As long as you already tried it- I was just looking for a simpler way to do this mod. I am going to do it- Maybe once I get back off Vacation.
This mod would be great when I get my rear tails tinted. Oh I also added an RED LED Strip that runs along the bottom of the trunk lid and only comes on when the Brakes are activated- Just for added insurance
THANKS
Old 06-24-2008, 08:25 AM   #7 (permalink)
DESIREE
Member Number: 1483
AWESOME!!!!!!!
THANKS
Hey now, there's an interesting application: to double the lighting when tinting the tails. They won't be any brighter, but there will be twice as many.
Oh, I've tried it alright.
Years ago I did a similar light socket modification in the brake lights of my
'97 Mustang Cobra so as to be able to install my own design sequential turnsignals.
From that experience I took a look at the C's lower running light and found, just like the Mustang, the two-element bulb was already there! A close inspection of the socket showed that tapping into the bright element of that bulb was even easier and cleaner the Mustang's.
DESIREE is offline
Old 06-24-2008, 10:14 AM   #8 (permalink)
SilverSurfer300
SilverSurfer300's Avatar
Member Number: 16337
Send a message via MSN to SilverSurfer300
Instead of drilling into the green socket, cant you just splice the new white wire into the black/grey stripe wire on the green socket?
SilverSurfer300 is offline
Old 06-24-2008, 02:06 PM   #9 (permalink)
DESIREE
Member Number: 1483
No. And for a several reasons.
First, the two-element bulb needs three wires: one for a common ground, one for the low brightness minor element (parking/running light), and one for the high brightness major element (brake light). If you look closely at the picture of the green socket you can see the labels "GRND", "MINOR", and "MAJOR". There is no wire exiting the socket for the "MAJOR" element so it has to be added.
Second, applying brake light power from the black socket to the minor element (that is when the brakes are applied) of the green socket would cross-feed power to the parking/running light on the other side of the car. This wouldn't be physically noticible as the other side of the car (similarly wired) would be trying to cross-feed also.
Third, when the parking/running lights are turned on, power would backfeed to the brake light in the black socket, which would have the brake lights on without stepping on the brake pedal.
DESIREE is offline
Old 06-24-2008, 02:10 PM   #10 (permalink)
300 Passion
300 Passion's Avatar
Car: 2006 Chrylser 300 Touring
Member Number: 18240
Very cool writeup! I think I may try this one!
300 Passion is offline
