Old 02-16-2008, 02:42 PM   #1 (permalink)
DMC
DMC's Avatar
Car: 2005 Chrysler 300 LTD Team Kartier
Member Number: 8890
wiring halos to sidemarkers
can i use the power from my side markers lights. the ones on the outside of the bumper to power both halos? or will it draw to much power from those lights?
DMC is online now
Old 02-16-2008, 02:46 PM   #2 (permalink)
Car: 2006 Chrysler 300
Member Number: 14521
from what i understand doing some reading, ( I just bought some halos) You really should use the side marker as a trigger and put a relay..
that way the relay gives you power directly from the battery, and the markers trigger the switch to turn them on and off... I could be wrong... Guys??
Dove dkla is offline
Old 02-16-2008, 02:49 PM   #3 (permalink)
DMC
DMC's Avatar
Member Number: 8890
what kind of relay?
DMC is online now
Old 02-16-2008, 05:02 PM   #4 (permalink)
MM-JAPAN's Avatar
Car: 2007 Chrysler 300C
Member Number: 11139
Mine are hooked up to the wiring to the bumper side markers and works just fine but when I get the fog halos I want to have all the halos connected to the battery directly and to a switch inside the car so I can turn the halos on at anytime. I am going to have it throught that the halos shut off when their is no key in the ignition.
Mods:
x AFE Stage II CAI
x 300C UltimatePedals
x 35% Tinted Windows
x Interior LEDs
x Billet Tech Everything
x LED Tail Lights
x 180 Tstat
x KW V1 Coilovers
x Cargo Molded Tray
x Mesh Grill
x IPOD Interface Kit
x ETC Toll Road Payment Device (Japan)
x NITROGEN filled Tires
x VIP 300 Inc Front/Rear Lips
x Modified Engine Cover
x Hotchkis Front/Rear Anti-Sway Bars
x Clear Bumper Lights
x Diablo Predator - 93 Oct & CAI tune
x 10000K Head & Fog Halos
x 8000K Head & Fog HIDs
x KOOKS LT Headers
MM-JAPAN is offline
Old 02-16-2008, 07:01 PM   #5 (permalink)
DMC
DMC's Avatar
Member Number: 8890
mm-japan do you have a relay
DMC is online now
Old 02-19-2008, 08:50 AM   #6 (permalink)
AACstyle.com's Avatar
Car: Escalade EXT/ Turbo Lexus IS
Member Number: 3553
No need to use a relay if you are tapping the side markers. If you are going directly off the battery you should use a relay (ie: installing a swith)
-Justin
Advanced Automotive Concepts
"Now serving all LX platforms!"
1(800)407-5776
www.AACstyle.com
No PM, email: justin@aacstyle.com
AACstyle.com is offline
Old 02-20-2008, 05:08 PM   #7 (permalink)
Car: 2005 Chrysler 300 Limited Touring
Member Number: 16611
is there any way you can hook them up so that dey can be like the bmw halos?
Eastside300 is offline
Old 02-20-2008, 06:53 PM   #8 (permalink)
AACStyle, hmm couldnt you just wire it using a relay and then trigger that relay from your side markers? Shoot I dont know you guys know more than i do. I was always told to run stuff like that directly off of battery...
ie. Battery to relay, then the side marker wire to the relay act as a trigger when on to draw power from battery/ off is off....
Old 02-20-2008, 07:03 PM   #9 (permalink)
Member Number: 1483
Radio Shack 275-001 or 275-226
DESIREE is offline
Old 02-20-2008, 07:04 PM   #10 (permalink)
DMC
DMC's Avatar
Member Number: 8890
wire them straight to the side marker lights then you can delete the orange blinker light and only have it coming on when you put the turn signal on.. it looks hott now
DMC is online now
