Old 09-04-2009, 04:19 PM   #1 (permalink)
Points: 1,910, Level: 1 Points: 1,910, Level: 1 Points: 1,910, Level: 1
Car: 2006 Chrysler 300C HEMI Protection/Navigation & Sound Groups II
Member Number: 15353
Can I install factory 300C HIDs onto 300C with factory halogen projectors?
I've got a 2006 300C fully loaded, but mising the HIDs.
This particular car 2006 has the LMTS Halogen Projector w/Delay Lamps
The original HID option is LMP High Intensity Discharge Headlamps
I do not want to mess with the atermarket kits, so the question is - what needs to be replaced besides the headlaps assemblies? I have a pair of original working HID headlamp assemblies in my posession.
P.S. I had the similar experience with 2006 Chrysler Pacifica. After replacing the headlamps assembies the HID ones they just blinked once and did not light (HIDs started fine off battery, started flickering when the engine was on, could shut down on high RPMs, also didn't start in colder weather).
The solution was the IPM (Integrated Power Module) replacement. This module contorls all loads and also has the underhood fuse block assembly on the top. There were 2 different part numbers for halogen and HID headlamps. So after replacing all 3 pieces (2 headlamps+IPM) the HID worked no problem, no programming needed. Since 300C has a CAN bus instead of J1850 there might be some programming issues as well, ot no need for IPM replacement.
It looks like 2006 300C has only one version of IPM 5161486AA
I have read this thread: factory HIDs in c without factory HIDs
Also this thread explains how to retrofit the halogen housing with the HIDs - not exactly my case How-To: OEM Hid Retrofit
toshik is offline
Old 09-04-2009, 05:06 PM   #2 (permalink)
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
it can be done, PM SuperT on LXForums, tell him I sent you, he has a dodge magnum he put a 300C front on and made the HIDs work, he can get you all the proper connectors part numbers and what he did to make it work.. he and I worked together over the phone on it for a few weeks until he finally got it.
the Magnum has the same wiring as the 300 with halogen lights, so his work should be 99% exact to what you need to do.
Mr. iNCREDIBLE is offline
Old 09-04-2009, 06:06 PM   #3 (permalink)
Thank you!
According to this source How-To: OEM Hid Retrofit it's a direct swap.
However the halogen factory version uses the low beams to blink-to-pass while the HID version uses high beams for blink-to-pass.
toshik is offline
Old 09-05-2009, 10:27 AM   #4 (permalink)
Member Number: 5683
Trader Rating: (21)
Originally Posted by toshik View Post
Thank you!
no both cars use the high beams as flash to pass, the low and high beam are single filiment bulbs, only time a low beam is used for flash to pass is when it is a dual filiment bulb acting as both low and high beam, like most motorcycles that only have one headlight
Old 09-05-2009, 12:35 PM   #5 (permalink)
Points: 7,562, Level: 1 Points: 7,562, Level: 1 Points: 7,562, Level: 1
Inferno07's Avatar
Car: 2007 Chrysler 300C
Member Number: 16364
Send a message via ICQ to Inferno07 Send a message via AIM to Inferno07 Send a message via Yahoo to Inferno07
Boy an aftermarket kit would be so much easier
I know that was a Captain Obvious moment and some people just like a challenge, but my aftermarket HID's (low's and fogs) have been going strong now for nearly a year and a half, I did replace one bulb about a month ago (a pair of new HID bulbs were $26.00) best $120 I ever spent!
Brett DiMichele
  • 2007 Inferno Red 300C
  • HIDGate 6000K HID Low Beam and Driving Lights []
  • AAC Red/White Bling Rings []
  • AAC Oracle Red Interior LED's []
  • Grillcraft MX Grill []
  • IPCW LED Tails []
  • Revelations S.S. Pillar Post Trim []
  • CDC Tech Trunk Filler Panel - Not yet installed! []
  • OEM SRT8 Trunk Spoiler - Not yet installed! []
3CF Will miss you Marc aka Mr.Incredible
Inferno07 is online now
Old 09-05-2009, 05:27 PM   #6 (permalink)
Points: 7,504, Level: 1 Points: 7,504, Level: 1 Points: 7,504, Level: 1
Fisch's Avatar
Member Number: 22401
X2! ^^
I haven't had mine that long, but the price difference is insane. I could swap out aftermarket kits many times and still save money in the long run as compared to OEM HID's.
Fisch is offline
Old 09-05-2009, 09:51 PM   #7 (permalink)
Originally Posted by Fisch View Post
X2! ^^
This is all great, but as I said before, I already have a set of original working HID headlamp assemblies. So in my case price does not matter. BTW the halogen projectors stink comparing to HIDs.
toshik is offline
Old 09-05-2009, 10:28 PM   #8 (permalink)
Points: 4,951, Level: 1 Points: 4,951, Level: 1 Points: 4,951, Level: 1
Car: 07 Chrysler 300C SRT8
Member Number: 6743
Yes you can do a swap. When you say "assemblies" does that include the entire housing? If so, then yes. If you only have the Projectors, they can be swapped out on the housing, but you have to make a few minor mods to the halogen housing in order to mount the ballasts to them.
Herminio has a how-to thread in the DIY here: How-To: OEM Hid Retrofit
There is also another detailed thread at the forums "that shall not be named" Check your PM :P
VYPER883
300C SRT 8... Pure Evil Dressed to the Nine's...
"Ever notice how you come across somebody once in a while you shouldn't have ****ed with? That's me." Clint Eastwood as Walt Kowalski in Gran Torino.
vyper883 is offline
Old 09-06-2009, 12:14 PM   #9 (permalink)
Yes I've got the entire housings and guess what? The low beams connectors for HIDs are 8 pins (2 pins used) and halogens are only 2 pins connectors. No big deal - did some soldering.
However I think I see some HID flickering after the swap when the engine is on.
Will follow up.
toshik is offline
Old 09-06-2009, 05:31 PM   #10 (permalink)
Points: 5,916, Level: 1 Points: 5,916, Level: 1 Points: 5,916, Level: 1
HERMINIO's Avatar
Car: TWO 2005 Deep Lava Red 300C's
Member Number: 442
Toshik, I did the first halogen retrofit almost five years ago using identical part numbers for the OEM HID's because the assemblies were not readily available used and new ones were very expensive. Mines were early builds, 2/04 & 6/04.
A few months later I exchanged the first retrofit because found used OEM HID assemblies and also did the first complete retrofit.
For the flickering I explained on my thread how to avoid it easily.
Enjoy and welcome to the "OEM HID retrofit club".
For me the benefit of the retrofit its that looks OEM, you pass inadvertently and do not blind the incoming drivers.
I still own both cars and the system never failed.
Herminio
Will follow up.
2005 300C HIS, DLR, WOOD TRIM, D2S HID, PILLAR SET, AIR DEFLECTORS, LIP SPOILER, TINTING, E&G GRILL, LOWER MESH INSERT, PAINTED ENGINE COVER, VES, AIRHAMMER, UC, UNDERHOOD LIGHT, BFG KDWS 245/55/18, PEDALS SET, CHROME TAIL BEZEL
2005 300C HER, DLR, OEM HID RETROFIT, PILLAR SET, AIR DEFLECTORS, WOOD TRIM, LIP SPOILER, TINTING, OEM CABIN FILTER RETROFIT, E&G GRILL, LOWER MESH INSERT, PAINTED ENGINE COVER, VES, AIRHAMMER, UC, UNDERHOOD LIGHT, BFG KDWS 245/55/18, PEDALS SET, CHROME TAIL BEZEL
HERMINIO is offline
