Old 10-21-2009, 12:56 PM   #1 (permalink)
Points: 2,399, Level: 1 Points: 2,399, Level: 1 Points: 2,399, Level: 1
Member Number: 8143
Headlights issue. . Please help!
Ok guys,
I just noticed my driver side head light goes in and out and I don't understand whats going on. When the light goes out, i turn both lights off then back on and this seems to fix the problem for a few seconds then the light goes back off. Any ideas?
Also my reverse lights and tag lights don't work. Any ideas on this issue? Does anyone know where the fuses are for these things? I asked the dealer and they are going to charge $250 just to check everything out and I don't know if its covered by the extended warranty since it is a 2006 300C.
Please Help because this is so annoying and times are hard right now.
Thanks
*Solo
Sol234 is offline
Old 12-23-2009, 10:36 PM   #2 (permalink)
Points: 40, Level: 1 Points: 40, Level: 1 Points: 40, Level: 1
R453R's Avatar
Car: 2006 Chrysler 300c
Member Number: 24938
Thats a tricky one without seeing it. Sounds like a complicated electrical problem. jsut pay to get it looked out. check the fuses first, DId you wire anything your self?
R453R is offline
Old 12-30-2009, 04:20 AM   #3 (permalink)
Points: 3,364, Level: 1 Points: 3,364, Level: 1 Points: 3,364, Level: 1
saleen8927's Avatar
Car: '06 Chrysler 300C SRT8
Member Number: 20505
Originally Posted by Sol234 View Post
Ok guys,
Thanks
1) are your headlights HID?
2) reverse and tag lights, silly question, but did you try replacing the bulbs? Although I admit it's not likely that all the bulbs would go out at once, you could buy a bulb for $2 at autozone and try it before spending $250 at the dealer.
Could also be a harness connection. I never looked in that part of the trunk for it, but I assume there's some sort of wiring harness, like with the taillights. I would say it's possible the harness was bumped out or somehow disconnected (or broken, for that matter). Open the trunk and look under the carpeting behind where the lights are - I would bet you can see the harness and see if there's an obvious problem there.
2006 300C SRT8 - Silver Steel - Predator, Janetty Racing CMR Tune, 180 TStat, AFE Stage 2 Intake, Satisfied Ceramic Pads, Toyo Proxes 4, 20% Tints, T-Rex Upper Class Grille, 6000K CCFL Halos, 6000K HIDGate Replacement Lows, 6000K HIDGate Fogs, Stealth Front & Rear Signal Bulbs, Stealth Clear Side Markers, Tinted Tails
saleen8927 is offline
