Old 11-08-2009, 09:58 AM   #1 (permalink)
Points: 26, Level: 1 Points: 26, Level: 1 Points: 26, Level: 1
Car: 1999 Chrysler 300
Member Number: 24427
Console lights turn on and off at will.
My wife's crysler 300 has some electrical issues. One of which the console lights will turn on or turn off randomly when driving with the lights on. Also the cigarette lighter wont work but I dont think the problems are related. I'm sure the answer is simpe however Im not a mechanic, can anyone help?
Deez300 is offline
Old 11-08-2009, 10:37 AM   #2 (permalink)
Points: 4,449, Level: 1 Points: 4,449, Level: 1 Points: 4,449, Level: 1
LuckyAce's Avatar
Member Number: 22917
Send a message via MSN to LuckyAce
Cigarette lighters going on any car is usually a fuse.
The lights would indicate there is a loose wire.
Sabrina - The Srebrna Djvenke
05 300 LTD AWD
To do list....
{_} Mirage doors
{_} Projector headlights/fogs, both with Halos
{_} 22" Avarus AV4 w/ ???
{_) Sway bar/shocks/struts/springs
The To-Do list has slowly been checked off.
LuckyAce is offline
Old 11-08-2009, 11:14 AM   #3 (permalink)
Points: 8,306, Level: 1 Points: 8,306, Level: 1 Points: 8,306, Level: 1
Activity: 93% Activity: 93% Activity: 93%
CoolVSRT8's Avatar
Member Number: 18060
Trader Rating: (7)
ditto what ace said
2005 Cool Vanilla 300C
CoolVSRT8 is offline
Old 11-09-2009, 06:15 PM   #4 (permalink)
Thanks for the info. I fixed the cigarette lighter and you were right it was the fuse, but do you have any advise on where I how should look for a loose wire?
Deez300 is offline
Old 11-09-2009, 06:20 PM   #5 (permalink)
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
is this LX or LH car?
the 2005 and newer LX cars have a TSB out about a loose ground behind the cluster that causes the dash lights and cluster to flicker in and out..
can't help onthe LH cars, don't know anything about them.
Mr. iNCREDIBLE is offline
Old 11-09-2009, 08:57 PM   #6 (permalink)
Points: 2,347, Level: 1 Points: 2,347, Level: 1 Points: 2,347, Level: 1
Concrete's Avatar
Car: : : :
Member Number: 21143
Does the ground pertain to only the cluster and dash or to all the lights except the navigation?
Concrete is offline
Old 11-10-2009, 11:15 AM   #7 (permalink)
Member Number: 5683
Trader Rating: (21)
if you pull out your cluster you will see a ground strap bolted to the framing directly behind the cluster.
that is the ground strap for the whole dash harness, so it effects everything attached to the dash, as well as the power window switches (if you have auto up and down)..
Old 11-10-2009, 12:50 PM   #8 (permalink)
Concrete's Avatar
Car: : : :
I'm hoping it's as simple as just the ground strap! Even my windows go down in a pulsating motion when the lights start to flicker... When I disconnect the terminal it does it real bad and the car acts as if it wants to shut off, I was thinking a bad alternator?
Any other ideas on how this could be fixed or what's causing it would be greatly appreciated. When I searched the forums for threads on flickering lights, most touch on HID's...
Concrete is offline
Old 11-10-2009, 01:07 PM   #9 (permalink)
Member Number: 5683
Trader Rating: (21)
there is a TSB out for that... lemme find it..
I think this is the one:
http://www.wkjeeps.com/misc/LX/TSB/TSB_0804906.pdf
Old 11-10-2009, 01:25 PM   #10 (permalink)
Concrete's Avatar
Car: : : :
For some reason the link won't download? Do I need to download some Adobe software...
Concrete is offline
