Fog lamp relay location? - Chrysler 300C Forum: 300C & SRT8 Forums
Lighting Discussion This area is for discussion of all things related to lighting. Such as: HIDs, Turn Signal Bulbs, LED tails, Interior Xenon bulbs, etc. for the Chrysler 300 or other LX models.
post #1 of 6 (permalink) Old 07-23-2011, 05:18 PM Thread Starter
Points: 14,545, Level: 1 Points: 14,545, Level: 1 Points: 14,545, Level: 1
Car: 2013 Chrysler 300C
My fog lamps don't work, and the dealer is telling me that they need to work to pass inspection. It happened a while ago, I'm not sure when (I rarely use the fog lamps), and the switch no longer lights up. I'd like to see if I can fix the problem before I have to bring the car in next week, since it also needs other work, and I'd like to keep the costs down if it's something I can diagnose/repair myself.
I checked the fuse, and that seems to be ok, but I can't find anything that tells me which relay controls the fog lamps.
I was also going to try to check the switch, but I don't see how to remove the switch plate easily.
Can someone tell me which relay I need to check? And if there are any other suggestions that I can try to fix the problem, I'd be most appreciative. This is a 2005 300C.
Cosmo is offline
post #2 of 6 (permalink) Old 07-23-2011, 05:30 PM
Points: 92,609, Level: 1 Points: 92,609, Level: 1 Points: 92,609, Level: 1
Tetris Champion
HPNO300's Avatar
Car: 2006 Chrysler 300 Touring and SRT8
Send a message via Yahoo to HPNO300
I was going to say try checking the fuse to make sure it is not bad but if you already checked that and it is fine then I am not sure
You could always go some where else for inspection....not one single place I have taken my car for inspection ever has checked to see if my fogs work properly.
HPNO300 is offline
post #3 of 6 (permalink) Old 07-23-2011, 09:34 PM
Points: 2,340, Level: 1 Points: 2,340, Level: 1 Points: 2,340, Level: 1
GRUMPE's Avatar
Car: 2013 Chrysler 300S
Just something that I noticed on my 05 limited that I just picked up. My 07 srtd works differently. On my 05 I can not turn the fog lights on during the day time if the light switch is in the auto position but if I turn the knob from auto to the parking light or headlights on position then I can turn the foglights on during the day.
At night there is no problem turning the foglights while the switch is in the auto position.
RON
GRUMPE is offline
post #4 of 6 (permalink) Old 07-24-2011, 12:51 AM
Points: 65,390, Level: 1 Points: 65,390, Level: 1 Points: 65,390, Level: 1
OoTLink's Avatar
Send a message via AIM to OoTLink Send a message via Skype™ to OoTLink
Grumpe: If you turn the foglights on when they are in auto (and on), then they will turn on whenever the headlights turn on. Unless your headlight switch starts to go out like mine did. I turned mine on, and.. they stayed that way. Now whenever the headlights are on the foglights are, too.
So now I'm one of those annoying people that always has their foglights on at night XD
OoTLink is offline
post #5 of 6 (permalink) Old 07-24-2011, 11:11 AM
Points: 68,190, Level: 1 Points: 68,190, Level: 1 Points: 68,190, Level: 1
It's in the front fuse box (aka IPM [Module-Integrated Power]). Pop the lid and look inside of it for a diagram of the layout. It's in the second row, second from the left. It's interchangable with any of the other relays in the second row, so swap one over to see if the foglights turn on.
This type relay is readily available at any auto parts store, even Radio Shack.
Also check Fuse #7 (20A) located in the IPM.
DESIREE is online now
post #6 of 6 (permalink) Old 08-09-2011, 07:31 AM Thread Starter
Thanks for all of the help everybody, I checked the relays and that wasn't the problem. The dealer ended up replacing the dashboard switch, and everything is working now. They replaced it with a newer switch which is different from the original- the fog lamps are turned on by pushing in the headlight knob.
Cosmo is offline
take to dealer to replace fog lamp? Jordan Lighting Discussion 10 09-24-2015 09:34 AM
headlamp washer pump and relay location?... peter 0723 General Discussion 3 02-26-2010 09:36 PM
Help!! cracked fog lamp covers Cool_V_300C Problems / Dealer Service 6 05-25-2007 06:52 AM
6 weeks and a blown fog lamp already!? cvp33 1st Gen SRT8-Specific General Discussion 29 04-17-2006 06:46 AM
