Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Supporting Vendors > Mopar Super Center
Old 05-10-2006, 01:46 PM   #1 (permalink)
Points: 9,013, Level: 1 Points: 9,013, Level: 1 Points: 9,013, Level: 1
pmpn8ez's Avatar
Car: 2006 Dodge Charger SRT8
Member Number: 2022
Trader Rating: (4)
factory sirius
For those of us with the huge, bubble 2005 factory sirius ant. is it possible to switch out the ant from one of the newer, smaller, square ones?
Is it available yet?
Halos, 22's, BT emblem, LED interior, Jl 12's, 2 sets of JL 6.5 components, JL 500/1 and 300/4, Tinted tails & sides, 35% Tint, factorone HID's, K&N Aircharger CAI, visor covers, MRK Silver knobs, 22elite padded center console & door rests, red stitched shift knob
now on to more performance goodies!
pmpn8ez is offline
Old 05-11-2006, 02:22 PM   #2 (permalink)
Points: 7,729, Level: 1 Points: 7,729, Level: 1 Points: 7,729, Level: 1
Car: 2008 SRT-8 Challenger
Member Number: 910
You have brought up a very good question. The antenna listings are different for 2005 and 2006, as well as the receivers. The accessory kits are also different, and we have no way of verifying if it is a direct swap. I think the difference is the bus communication system, and we do not know if it would have an adverse effect or not.
Ted@ALLUSA is offline
Old 05-11-2006, 05:04 PM   #3 (permalink)
Points: 3,149, Level: 1 Points: 3,149, Level: 1 Points: 3,149, Level: 1
Car: 2002 XL7 Suzuki
Member Number: 4606
You think thats big, wait until you see the new sat antenna for the Pacifica, lol. Picture of it in this months Mastertech for those at DCX dealerships. I have an older antenna laying around, next time I have a headliner down in one with the newere I will try to check and see if the connections and mounting match up.
ktek01 is offline
Old 05-13-2006, 08:33 PM   #4 (permalink)
Member Number: 4606
I had one down today and compared them, the big one uses two antennna cables, the small antenna uses one. So it doesnt look like you can swap them over without changing the receiver. You would need the factory replacement parts, not the Mopar kit, the Mopar add on kit is still being shipped with the big antenna.
ktek01 is offline
Old 05-15-2006, 09:03 AM   #5 (permalink)
pmpn8ez's Avatar
Member Number: 2022
Trader Rating: (4)
Thanks for the feedback guys. I guess Ill live with the bubble.
pmpn8ez is offline
Old 05-25-2006, 07:31 AM   #6 (permalink)
Member Number: 910
The plot is beginning to thicken here. We just had to replace an antenna module on a vehicle in the shop. The new module only has 1 antenna connection, and there is some TSB regarding this. So I will be doing a little investigative research to find out what the deal is. It may turn out that the 2 wire system is now replaced with a single system.
Old 05-26-2006, 03:21 AM   #7 (permalink)
Points: 3,452, Level: 1 Points: 3,452, Level: 1 Points: 3,452, Level: 1
jaak's Avatar
Car: 2006 -- SRT8 Magnum -- 11 Second Magnum SRT8 - 300C in wolf's clothing
Member Number: 3322
There are commonly available two wire to single wire converters for this. The plastic shells on the connectors will need to be removed and the metal part of the connector plugged in, then secured with tape, or heat shrink tubing, as the Chrysler version is keyed differently.
http://www.crutchfield.com/S-QQDt8K9...750&I=209SIRSP
You don't even have to use the Chrysler antenna...
http://www.crutchfield.com/S-QQDt8K9...0&I=209SIRMINI
Some background on this... The first system was two wire. One part number gave you the two wire antenna and receiver and mounting bracket, the other part number gave you the wiring harness and two wire antenna cable.
The newer kit is a single wire antenna (lower profile) and receiver (about half the size of the first kit) with velcro to attach it, instead of a bracket. The harness kit gives you the matching single wire antenna wire and harness.
jaak is offline
Old 05-30-2006, 07:10 AM   #8 (permalink)
Member Number: 910
Good info, thanks
Old 05-30-2006, 06:49 PM   #9 (permalink)
Points: 5,567, Level: 1 Points: 5,567, Level: 1 Points: 5,567, Level: 1
Member Number: 73
Originally Posted by Ted@MPSC
Good info, thanks
I had an early production 300c. Took delivery of it on 4/7/04. I now own a 2006 300C that was built July 2005. They both have the big sat. antenna.
upstate is offline
