Go Back   Chrysler 300C & SRT8 Forum > Supporting Vendors > Mopar Super Center
Old 04-11-2005, 09:55 AM   #21 (permalink)
O Stress's Avatar
Member Number: 1564
Originally Posted by RamVett
Sounds good....I'll see if local AutoZone stocks it. Any secrets on how to make the end cuts look good?
that depends on where you are using it... i do a slight angle cut on mine, then do a touch up on the ends with an artist brush, and chrome paint from a spray can, just spray some in the lid, and there you go.. its such a mi-nute cut, you can't see the difference with the touch up...
it's also best to pre-heat the area before application, so the trim holds fast...here is a better pic of the trim..............................
O Stress is offline
