Go Back   Chrysler 300C & SRT8 Forum > Off-Topic Forum > Off-Topic Discussion
Old 02-20-2007, 11:14 AM   #1 (permalink)
Member Number: 2476
Need HELP ADVICE and TIPS for Building a Room
Well Im the type of guy that is handy for everything.
I like to build and make things as well as install things.
Pretty much all of my friends call me first when there is a problem or if something needs to be done.
Yesterday my friend asked me to take a look at his apt that he is moving into and his room has a closet that is just a mess.
the floor and walls are concrete and the ceiling has pipes.
I told him I can put up sheet rock on the walls, but Im not sure about the ceiling.
I never did this before but I know that I can do it with my handy skills.
Im just asking for advice.
I was also thinking of adding a couple of poles to hang clothes and some shelves.
I know Ill need the usual sheet rock and wood beams, and how about those metal things that you put the wood beams in for the corner?
also, how would I go about making a celing if I do?
I pretty much have the layout in my mind, but I wanted to get some helpful hints and tips or if there is anything major that I will need.
I will not be doing the electricity so no worries about that.
Regards
Bert
BTW, Tim, maybe you can hlp me cause I know u did a project a while back.....
NautcaSprt6 is offline
Old 02-20-2007, 11:28 AM   #2 (permalink)
GoofyTimL's Avatar
Member Number: 3755
I've done a couple actually... but in reality the contractors did it, not me. I don't have the patience or the time it would take me to do such things.
Sounds like you've got the drywall thing down for the walls. Just use furring strips and add some 1/2in foam insulation. On the floor I'd look at the composite cork flooring like I did in our basement... makes for a soft and warm surface (perfect for sock feet and a closet).
If the pipes up near the ceiling are the kind of pipes to which you need access, then I'd suggest a suspended ceiling. I have done that type of install, and in a small space that shouldn't be too difficult at all. Thereby you can maintain the needed access to the pipes. You'll just need approx. 1.5-2 in clearance above the top of the panels in order to get them in or out.
What about light in the closet? Options are a can system incorporated into the ceiling (more difficult), or just a socket on one wall with a pull chord. Depends on how "public" this closet will be.
GoofyTimL is offline
Old 02-20-2007, 11:48 AM   #3 (permalink)
pipsdad's Avatar
Car: 2000 Dodge RAM 1500 4x4
Member Number: 9889
Send a message via Yahoo to pipsdad
You have not mentioned the size of said closet. It would be good to know this in order to make a recommendation regarding the ceiling!
pipsdad is offline
Old 02-20-2007, 12:02 PM   #4 (permalink)
Member Number: 2476
There already is a light in there and I will put the sheet rock around it.
Im not gonna be doing any electrical work.
Its about 10-4 feet big.
Old 02-20-2007, 12:05 PM   #5 (permalink)
jjs
jjs's Avatar
Member Number: 404
Before you do anything, I would make sure hte management/landlord doesn't care that you are modifying their building.
2005 Silver C
2005 Silver Lexus ES330
1997 Ram
jjs is offline
Old 02-20-2007, 12:14 PM   #6 (permalink)
Member Number: 2476
Na, im in the clear, so thats ok.
Old 02-20-2007, 12:29 PM   #7 (permalink)
crhemi's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 3307
Burt- Shoot us some pictures and take some measurements, then we can give accurate advice/direction from there.
Bill
crhemi is offline
Old 02-20-2007, 12:42 PM   #8 (permalink)
chasb's Avatar
Member Number: 3019
Dropped ceiling...
...if there is room and clearance. I believe you need around 10" from the original ceiling down to be able to run the metal runners for the dropped ceiling and be able to slide in the tiles
Use the 24" square tiles not the 24 x 48 so they are easier to work with.
You can get all of the material and a how to guide fom Home Depot or Lowes.
Super Chips Tuner flashed
chasb is offline
Old 02-20-2007, 02:28 PM   #9 (permalink)
italianguy63's Avatar
Member Number: 10316
Send a message via Yahoo to italianguy63
You could sheetrock the ceiling too-- 24" centers on 2 x 4s if the span isn't too long... you said 4'... so no sweat there. if there is a light fixture there you could drop it (the box) onto one of the 2 x 4's or install one of those cheap plastic (blue) boxes from home depot.. the sheetrock is the cheap way to go-- but a pain to do all the taping and texture-- (more labor).
Bright Silver 2006 300 Touring "El Patron"
Stealth Auto projection headlights, Kayee
mesh Bentley grill, SilverStar/Stealth bulbs,
RAQ radio upgrade, Sirius, auto headlamps,
lip spoiler, de-emblemed and "B"-emblemed,
tint, clear side marker lights, clear K2 LED
Altezza tail-lights, the "Luke" subwoofer
solution in rear armrest, Bob's Blasters dual
exhaust, Eonon 9.2" headrest LCDs, Sony
portable DVD player (center console).
Brilliant!!
italianguy63 is offline
Old 02-20-2007, 09:31 PM   #10 (permalink)
srt8danno's Avatar
Member Number: 1971
Bert when you get this done give me a call and I’ll have you whip up my new 20 x 40 addition.
srt8danno is offline
